Irregular Tire Wear Question - NT05's
Hoping for some analytical guidance here...I have been using the same set of Nitto NT05's for both the track and street for 5 track days (road course) and about 6000 street miles. I've taken them off for brake work before and after each track weekend, but just noticed this issue after taking them off to install tow hooks. My last track event was fairly hot (~90ish) and I ran 26psi cold all around (worked up to 31psi hot). Any ideas why on the center tread strip, one the inside edge is near 3/32" and the outside of the center strip completely flat? (stock alignment specs by the way) Thanks!
Mine do the same thing at auto-x. I just flip them when they do that, and don't think its anything abnormal. I think its mostly due to tires' tendency to "round-off" sharp edges during cornering, which is why the edges facing the outside are round and the ones facing the inside are squared.
Received 8,958 Likes
Mine did the same thing. Sort of reminds me of the old BFG R1s from the 90s and their groove of doom. They asymmetrical tires that worked well on camber challenged cars and if you ran too low of an air pressure the tread would buckle on hard cornering cause a very similar wear groove near the center of the tire. It might be time to rethink the proper hot pressures for these tires. Instead of aiming for the low 30s maybe they should be in the high 30s.
Bill
Bill
Since the center is not wearing uniformly, the thought is that the tires may not be inflated enough, causing the outside to buckle when cornering. I think if they were inflated too much the center stripe would be worn more than the outsides, but would be more uniform in the wear pattern than what I'm seeing. I also noticed that the wear triangles on the sidewalls are almost gone on my fronts, again hinting to too low pressures. Disagree?
If the photo from your avitar is an indication you are running a roval? Dont drop pressure to much, the odd thing is I always gained 8-10 psi with NT-05's front and 6 psi rear.
I looked for 33 hot and had the same wear. They turned to rocks at about that point.
Check your pressure gauge. Those tires look overinflated.
Also verify your alignment again. I've seen that same wear pattern occur on a vehicle with too much toe in. In my case the alignment machine said 1/16" of toe in....it was actually 1 1/16".
I bet if we were able to take tire temp measurements on the 05s pictured we would find very high temps on the outside followed by almost as high temps on the center outside edge and getting less as we check going across the tire from outside to inside.
Bill
I have run many sets of these tires and this is normal. Do not flip the tire on the rim until the outside edge is worn enough to do so.
I start the session at 31F/26R in a 3800lb Camaro with 385 to the wheels.
Nothing to be concerned about.
To add more info to this discussion, I have a pair that are the same size worn down to the bottom of the wear bars and the still have some tread on the shoulders. They were flipped once. I'm going to be getting a fresh pair soon, and when I get them will measure the tread depth across the face. I'm curious if they are shallower in the center than the edges when new. If so, even wear could look like over-inflation even though it isn't.
Add pressure The tire carcass is flexing on turn in and the center tread bar wear is the proof. When I had factory support years ago running BFG's the engineers blamed too low pressure on the "groove of doom" and damnit if they weren't right! I'd also call it somewhat normal from what I've seen. Adding pressure may reduce it, but doubt it will eliminate it.
These tires get a bad name because of it.
I'd be curious to see what tire temps look like with higher pressures. For auto-x, I can only get them to really work when the ambient is 90+ and bright sunshine. Higher pressures may cause them to run cooler, preventing them from reaching their operating temperature.
Starting with 31F/26R I gain 3-4 PSI and the grip is like a totally different tire.
I started with these tires at 35F/30R and wondered WTF?! As I was all over the place, I wasn't any faster than I was on my junk $99 each Maxxis street tires.
I kept dropping starting pressure until the tires came around.
