C6-Z06 Brake Ducts
C6-Z06 Brake Ducts
Brake cooling ducts seem to be a popular upgrade.
Curious though as I have a C6-Z06 (2008) and it appears I already have brake cooling ducts.. Is the difference with the aftermarket kits just the hose that runs to the rear of the rotor? If so does that mean all I would need is a hose?
If the full kit is needed then which one should I get? Like everything there are a dozen options .. I see XplosivePerformance has one, as does DRM, Quantum, LG, and no doubt many others as well.
Thanks.
Thanks.
usually they add some pipe to the end of the duct so it will hold the hose better:
you can just run the hose to the brakes like this:
or buy a kit to do this:
http://www.lapponline.com
