2009 ZO6 Corvette Track/Race Car
Former Vendor
St. Jude Donor '13
FOR SALE
Engine has less than 10 run hours
FOR SALE
New LS 7 Block, Large Comp Cam Hydraulic Roller, Callies 4340 Crank, Diamond Forged pistons w/anti friction coating 12.5:1 Compression, Clevite H Bearings mains/rods coated, Racing Hydraulic Roller lifters, Callies 4340 Forged I Beam Rods, 6.125 Length w/ARP 2000 Rod Bolts, Mahle Plasma Performance Rings, Cloyes Billet Roller Hex Adjust w/HD Z Chain, Katech Internal Oil Pump, ATI Performance SFI Damper, ARP Damper Bolt
Cylinder Heads
LS7 Heads CNC Ported Stage 2 CNC Port, blended, Manley Severe Duty Stainless Steel Intake Valves 2.20, Manley severe Duty Stainless Steel Exhaust Valve 1.65, ARP Head Bolts, Fast Intake LSxR 102 w/70mm throttle body restrictor, 64 CC Combustion Chamber, Flowed 385CFM @ .650 Lift, Polished Double Valve Springs, Lightweight Tool Steel Retainers & Hardened Locks, Comp Cams 1.8 Rockers w/ trunion Upgrade Kit, Smith Brothers 3/3 .083 wall hardened Pushrods, Siemens Deka 61Lb injectors
Crank Horsepower 671HP/588 ft-lb Torque
Tune HP Tuners by Ben at XP Motorsports
589 RWHP
Suspension
589 RWHP
Suspension
Pfadt Heavy Rate Front & Rear Sway Bars, Pfadt C6 Z06 Spherical Bearing Kit , Race Spherical Bearings, Pfadt C6 Z06 Transmission Mounts, Pfadt C6Z Engine Mount Kit, Penske 3 way adjustable Coilovers w/Remote reservoirs
BRAKES
Brembo 6-Piston Monoblock | 380x34 mm (15") | 2-Piece Discs Type III High Thermal Front, Brembo 4-Piston Monoblock | 345x28 mm (13.6") | 2-Piece Discs Rear, Hawk DTC70 Front pads, DTC60 Rear pads, Stainless Steel Brake Lines, Motul RB600 Racing Brake Fluid
Many Many other items, RacePak data acquisition, Cool Suit set up, Dual Oil Coolers, Dual Brake Cooling Ducts, SCCA<NASA<IMSA< GRAND AM Approved Full Roll Cage, Recaro Seat, Schroth Belts, Fire Suppression Aqueous System, Quarter Master 7.5 triple plate Clutch
Professionally maintained
In the right hands Sebring Lap times 2min 17 sec
Miami Homestead 1min 30 sec
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
Car has never been wrecked or off track. We have all records for car we built and maintain car for owner
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
Former Vendor
St. Jude Donor '13
Follow the links below and there are a number of pic's
The pic's are of this car and the cars we build and work on
http://pinterest.com/xpmotorsports/zo6-corvette/http://pinterest.com/xpmotorsports/
The seats are mounted on a solid aluminum frame bolted to the factory seat studs
Former Vendor
St. Jude Donor '13
FOR SALE
Cylinder Heads
589 RWHP
Suspension
BRAKES
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
Former Vendor
St. Jude Donor '13
FOR SALE
FOR SALE
Cylinder Heads
589 RWHP
Suspension
589 RWHP
Suspension
BRAKES
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
Former Vendor
St. Jude Donor '13
FOR SALE
FOR SALE
Cylinder Heads
589 RWHP
Suspension
589 RWHP
Suspension
BRAKES
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
ZO6 Corvette
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
ZO6 Corvette
Former Vendor
St. Jude Donor '13
FOR SALE
Cylinder Heads
589 RWHP
Suspension
BRAKES
$75,000 OBO
CALL
XP MOTORSPORTS
640 Poyner Dr
Longwood, Fl 32750
888.493.8041
PM
