Lottes + Blu808 C5 Build
Old 04-03-2013, 04:31 AM
Timothy Lottes
Timothy Lottes's Avatar
Default Lottes + Blu808 C5 Build
Long time lurker on this forum, starting this thread to show the build of my C5 corvette. This car is getting constructed just for HPDE. I stripped the car down, removed the roof, trimmed the doors, etc. Luke Lonberger and crew at CLP Motorsports in the Bay area are doing an awesome job on the fabrication. When the car is finished I'll be tracking it in the North Carolina area.
Direct Links to Updates in This Thread
2: Windshields and ACP Body Work
3: Engine
4: Rear Firewall and Windshield Frame
5: Firewall and Intake
Update 1
Started with my 1999 C5 hardtop. Really miss driving this car on the street. If I was wiser at the time I would have kept this car for the road and purchased another to destroy into a track car. Here is starting the cage. The main hoop goes to the frame with temp pockets cut in the rear tub to get the cage back without any extra bends.
Early work on the rear part of the cage.
Steering and pedal assembly. Cage has nascar style bars on both sides (keeping a passenger seat) extending into the hollowed out door area.
Wing mounted. Doing something different for this car, not keeping the rear bumper body work, more on this later in the build.
Radiator adjusted for front breathing, more work to be done here. Was originally planning on tubing the front of the car (can see the cut lines drawn), but ended up deciding to leaving the box frame.
Some ACP World Challenge body work up front. Aero tubing down to the splitter is very solid. Running 315 square setup on this car (for ease of spare) but not a wide body. Like the rear, the cage ties into the front suspension. Dry sump tank mounted inside the case passenger side where part of the stock firewall was. The stock motor is still in the car at this point, but looking at fitment for twin intake. After radiator venting was finished (more later) ultimately decided to do a full custom firewall and run the intake backwards (in progress now).
Midway into the radiator venting. Everything is designed for ease of maintenance. The exit venting box is easily removable, likewise the entry box is similar (not pictured here), and front body work is easily removable.
This is before mounting the correct engine, cutting out the stock firewall, etc. The undertray+splitter is mounted in 7 places with everything easy to service (front bar mounting visible here).
More next time...
Old 04-03-2013, 06:30 AM
StreetSpeed
StreetSpeed's Avatar
Neat. And this is just for HPDE? You go all out I guess...
Old 04-03-2013, 11:35 AM
PA Z06
PA Z06's Avatar
Looks like a great build, pretty serious DE car
Old 04-03-2013, 02:06 PM
rmackintosh
rmackintosh's Avatar
Looks sweet....
Old 04-03-2013, 04:08 PM
heypal
heypal's Avatar
Awesome build.
Old 04-03-2013, 04:10 PM
Paul Schmidt
Paul Schmidt's Avatar
Luke and his crew do great work. Can we get more pictures?
Old 04-03-2013, 04:21 PM
Kubs
Kubs's Avatar
Received 1,722 Likes on 931 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Awesome build! Looking forward to more pictures and details!
Old 04-03-2013, 10:57 PM
Timothy Lottes
Update 2
Went with Racing Shields for the front and rear polycarbonate windshield (I have a C5 hardtop). Payed extra for the "Stock Trimmed" option, but both front and back were still oversized and required extra trimming for install.
The front fascia, splitter, and tunneled undertray are from ACP. Kerry (owner at ACP) was quite helpful. The undertray is designed to easily mount to modified front sway bar brackets. Here is a shot of one of the brackets Luke modified,
This ACP setup requires trimming for install. The undertray ships oversized (see photo below). This was confusing at first because it requires cutting into the honeycomb of the undertray. Afterwords the undertray mounts under the front splitter and then the fascia mounts onto the splitter.
Old 04-05-2013, 01:34 AM
Timothy Lottes
Update 3
Continuing with undertray mounting,
Engine started from this Blu808 built 402ci stroker, later modified with ARE dry sump and Ozmo dual intake,
Solid mounted,
Solid mounted as low as can be done with stock front cradle and ARE 1005M pan,
Running LG Motorsports headers,
Ozmo intake running backwards since to low clearance from radiator exit. Currently working on new firewall and intake piping. Current thinking is 90 bends running tubing under windshield area to left and right air boxes filed from naca ducts on back part of hood towards outside,
Old 04-06-2013, 05:02 PM
Timothy Lottes
Update 4
Rear firewall is removable, still need to seal after body gets paint,
Kept the stock windshield pillars,
Windshield pillars were cut so the cage could fit slightly inside the pillar,
Has great visibility,
Old 04-09-2013, 09:49 AM
Woods
Woods's Avatar
Awesome job Subscribed
Old 04-13-2013, 09:29 PM
yooper
Support Corvetteforum!
yooper's Avatar
Subscribed as well
Old 04-14-2013, 01:24 AM
z06801
z06801's Avatar
a little more on that intake!
Old 05-02-2013, 11:27 PM
VRYALT3R3D
VRYALT3R3D's Avatar
St. Jude Donor '12
Great build so far
I love Blu808's stuff
Old 05-06-2013, 03:11 AM
InflatableDog
InflatableDog's Avatar
Sick build!
I have been to the shop a few times and the car is amazing in person.
Not sure if you follow the Blu808 guys on facebook but have you seen what they posted up today?
Looks like they finally pulled the trigger on making an entirely new bolt on suspension system for the C5/C6 cars.
Looks to be like every component of the cars suspension gets replaced with an adjustable billet piece.
Here are the teaser pics that were posted.
They should have more info soon as they mention.
Maybe you can shed some light on this new system? Are you going to be testing it with them?
Old 05-09-2013, 08:38 PM
Timothy Lottes
Yes, looking forward to it! But cannot add any extra info right now.
This is probably a good time to mention that I might not keep my stock parts as spares, in case anyone is interested in buying them. For instance, I've got clean and well maintained <10K road miles (no track miles) control arms with new and still unused Pfadt spherical bearings and ball joints installed.
Old 05-11-2013, 03:08 AM
Timothy Lottes
Update 5
Progress on the firewall and intake. There is a removable heat shield around the dry sump tank with venting from the side with an exit close to the center tunnel.
To Lottes + Blu808 C5 Build
Old 05-11-2013, 03:32 AM
moespeeds
moespeeds's Avatar
Very nice! Why black and white pictures?
Old 05-11-2013, 11:04 AM
Timothy Lottes
I like B&W better, after paint on final assembly I'm likely to go to color.
Old 08-18-2013, 08:25 PM
FuriousDonuts
FuriousDonuts's Avatar
Quick Reply: Lottes + Blu808 C5 Build
