Gutting windows on C5 race car
Old 03-25-2013, 03:39 PM
JohnAlley
JohnAlley's Avatar
Default Gutting windows on C5 race car
I am wanting to remove the driver and passenger size windows and all hardware from my C5 racecar to reduce some of the useless weight. My question is how do you open the door if all the hardware is removed? Dont really want to reach outside to open the door. Any photos of your setup would be greatly appreciated.
Old 03-25-2013, 04:19 PM
rfn026
rfn026's Avatar
I left the outer handle in place. When I want to get out of the car I just reach over and use the outer door handle.
Richard Newton
Old 03-25-2013, 10:34 PM
CP Thunder
CP Thunder's Avatar
Its easy to rig a pull tether.......I will get some pics of ours tomorrow morning.........
Old 03-25-2013, 11:43 PM
crimlwC6
crimlwC6's Avatar
you can retain the factory inner handles if you want and still remove the windows and motors.
Old 03-25-2013, 11:54 PM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
This worked good for me, not enough weight to be concerned with..
Old 03-26-2013, 06:46 AM
JohnAlley
JohnAlley's Avatar
Thanks, the photo really helps me see what I need to do.
Old 03-26-2013, 06:49 AM
C5ZEE06
C5ZEE06's Avatar
Anyone have a feel for about how much weight a gutted door is worth ?
Old 03-26-2013, 08:15 AM
sperkins
sperkins's Avatar
A crap load.
Old 03-26-2013, 08:40 AM
geerookie
geerookie's Avatar
Originally Posted by sperkins
A crap load.
And if you cut the reinforcement bar out "A crap load" X 2
Old 03-26-2013, 03:47 PM
RAFTRACER
RAFTRACER's Avatar
windows and regulator are 18lbs per side if I remember correctly.
Old 03-26-2013, 03:59 PM
drivinhard
drivinhard's Avatar
you guys obviously need to go to a gastro doc
Old 03-26-2013, 06:12 PM
geerookie
geerookie's Avatar
I friend of mine up here who runs with NASA is one of those.....I only follow him, I never let him follow me
Old 03-27-2013, 10:16 PM
johns68
johns68's Avatar
Just did this last month, and weighed everything I took out ... not as much as I expected, but still a lot. Panel, window, regulator, speaker, computer module and wiring harness = 24.5 lbs per side. I left the inside latch handle like Beretta did and won't cut out the inner shell and reenforcement bar until the cage goes in.
Old 03-27-2013, 11:33 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,106 Likes on 720 Posts
There you go, John. That should be enough to move you into TT4. I'm bringing my scales this time.
Old 03-28-2013, 07:05 AM
JohnAlley
JohnAlley's Avatar
Will be at 3200 lbs with driver meeting the NASA 8:1 Hp/Wt ratio
Old 03-28-2013, 07:43 AM
jlutherva
jlutherva's Avatar
If you need the name of a company that can help you w/ removable side windows for the pits or trailering, let me know. I found one that provides sheet lexan or plexiglas that is roughly cut to the right shape and has the right bend to it.
Jim
Old 03-28-2013, 08:13 AM
C5ZEE06
C5ZEE06's Avatar
Thanks for that. I imagine the Inner shell and reinforcement bar could be worth several additional lbs each side - eh ?
To Gutting windows on C5 race car
Old 03-28-2013, 08:55 AM
drivinhard
drivinhard's Avatar
big time
Old 03-28-2013, 12:06 PM
jtmck
jtmck's Avatar
What are Bills class numbers again?
I am running at 3500#. Where do I fit??
Jim M.
Old 03-28-2013, 12:57 PM
SouthernSon
TT6.
Quick Reply: Gutting windows on C5 race car
