TPMS reset not working and have a track day tomorrow
So I just bought CCW Wheels with tpms wrapped in kumho v710s and through them on for a track day tomorrow. I have a 2012 Grand Sport.
I put the car in accessory mode, hold down the lock and unlock buttons until the car beeps. I went to the front left tire and pressed learn, I get a beep. Same thing with front right. I go to rear right, and nothing happens. I've even taken the car of out accessory mode, back in to accessory to restart the process, and now I don't get any beeps, regardless of whether I try and start over by going to front left wheel or the right rear wheel where I left off.
What do I do? I'm going to be screwed for tomorrow if I can fix this. Either that, or I have to throw my street tires back on and hope I can reset those.
You can bleed air out of the tires to get a beep. I think it's 5psi up or down. Otherwise it's a defective or missing TPMS sensor. Hope you can get it fixed for MSR 3.1 tomorrow. Awesome configuration!
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Give me a buzz at the shop if you need help..
Might want to drive the car around the block in case the sensors shut off, might need to 're-activate' them so to speak.
972-429-1963
972-429-1963
Thanks guys. Finally got it to work. At Anthony's suggestion, I drove the car around for a while and tried the reset again, this time parked a good 30 feet away from my OEM wheels in case there was interference. No luck. After trying repeatedly, I was also getting a low battery light. Ran down the street and put in a new battery. The rear right took several times but it paired up and rear left picked up immediately. I finally got the magic double honk. What a relief and what a PITA!
Jim
The 2010 model year, and a 2011 built in December 2010 or prior will have the sensors that can be triggered by changing air pressure, or by using a TPMS tool.
Starting in January 2011 they began installing a different sensor (same TPMS, just a different sensor) that can only be triggered by a TPMS tool.
The problem was that a bunch of GM vehicles used that same sensor (Malibu, Impala, HHR, etc.). When they had a couple of those cars in a dealership, if they were programming a new set of sensors into your Vette and put it into the learn mode, if a Tech a couple bays down was simply adjusting air pressure in the tires of a Malibu, that would trigger the Malibu's sensor and the Malibu sensor would be programmed into your Vette's TPMS.
That's why they changed to the black sensor in January 2011.
Here's the sensor that will trigger with a change in air pressure, and you can see the GM part# molded into the case:
Here's the sensor they started installing in January 2011 (GM part# 20925924):
Either sensor will work in a 2010-2013 C6, but only the green one can be triggered by changing air pressure.
So....if you have a 2010 or newer C6 and are getting a second set of sensors, you might want to get the green 15268606 sensors.
There are lots of used ones available on eBay because they have been used on many other vehicles for a number of years - and they're pretty cheap!! They may not be readily available in the GM parts system because they've been superseded by the black sensor.
However, changing air pressure in the tires to trigger the sensor requires you to adjust air pressures after the procedure, so using a tool will be quicker and easier.
Bob
wow, then went BACK to the C5 style........ another tech "issue" I hate about most C6's.
Give it a door "****/handle", and "key", and the C6 is easily the best Corvette ever built to date, and likely to ever be built
Just a tip: sometimes when a particular sensor does not activate, I move on to the next sensor and then come back to it. Sometimes it works better when trying to activate after a short wait. I know that it will mess up the matchup of psi data to the correct wheel position, but that is not a big deal.
Thanks again to Anthony at LG for helping me troubleshoot via phone call on a Friday night. What other shop would do that?
As a follow up, I had the same issue getting TPMS to reset after putting my street wheels/tires back on last night. The left rear sensor (which is the last one you pair) wouldn't pick up. I finally drove the car around and parked in an open area, and they all paired up. Can't help but wonder if something in my garage was causing interference. Resetting worked a lot easier in an open area with a fresh battery. If anyone else has the same issue, give that a try and maybe it will help.
FYI this is the reset tool I got from TireRack:
http://www.tirerack.com/accessories/...&affiliate=FW9
He sent me a PM with his number offering to help, but I was already on the phone with Anthony from LG. I'm lucky to have guys like you around!
On another note, thanks to Keith Verges for having us out for a member day last Saturday on the 3.1 Mile at MSR in Cresson. This was my first time on the 3.1 and my first time on R Comps. Quite a learning experience. Here are 4 of my laps that were each below 2:30 without traffic. Last lap in this video was 2:27.1, which I equalled again later in the day.
http://www.youtube.com/watch?v=FbLhBHE_Q9w
They held up well. People warned me that R comps are worse than street tires on the track until they get hot, and they are absolutely right! They needed a lap to get warm and another to get hot, then you can really rip on them. That video starts on my third lap. I have heard a few people suggest the v710 is a decent Autocross tire. While I have never autocrossed, I would think it is an absolutely lousy tire for autoX. It isn't sticky fast enough for that.
I drove them to the track and back home with no issues. 4 sessions plus the drive there and back is 6 heat cycles. I will run them until they cord to get my $$ worth, then probably buy scrubs to manage cost. I can't see spending $1,500 or more for new Hoosiers when I am not actually racing.
