StopTech 97-04 Chevrolet Corvette Front BBK w/ Red ST-60 Calipers Slotted 355x32mm Ro
Former Vendor
St. Jude Donor '13
StopTech 97-04 Chevrolet Corvette Front BBK w/ Red ST-60 Calipers Slotted 355x32mm Rotors
StopTech’s® Balanced Brake Upgrade system is Engineered to directly replace the stock system, providing the correct brake torque output using the vehicle’s original master cylinder and no additional proportioning adjustment. Each StopTech® big brake kit includes forged 2-piece aluminum calipers with our patented bolt-in bridges, AeroRotor® two-piece brake discs with aluminum hats, StopTech® street performance brake pads, caliper adapter brackets, DOT-compliant stainless steel brake lines, and all hardware requiRed for a complete installation. Before ordering a StopTech® big brake kit, make sure you print out our wheel fitment template to determine if the StopTech calipers will fit behind your existing wheels without interference.
Big Brake Kit 2pc Rotor
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
http://www.xplosiveperformance.com/S...s-_p_3183.html#
$2699.95
Delivered lower US
Choice of Caliper Color
Red
Black
Silver
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
Former Vendor
St. Jude Donor '13
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
Former Vendor
St. Jude Donor '13
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
Former Vendor
St. Jude Donor '13
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
Former Vendor
St. Jude Donor '13
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
Former Vendor
St. Jude Donor '13
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
6-Piston
Rotor: 355 x 32mm /
Iron Slotted
Axle: Front
$2699.95
Delivered lower US
Red
Black
Silver
