C6 oil pan vs. C5 oil pan??
Old 07-05-2012, 05:34 PM
mountainbiker2
mountainbiker2's Avatar
Default C6 oil pan vs. C5 oil pan??
I spun bearing last weekend do to oil starvation. My understanding is that a C6 oil pan might help this problem. What do you think? It cost $400 for it.
thanks,
Steve A.
Old 07-05-2012, 06:11 PM
bsalie99
bsalie99's Avatar
I have heard that the C5 bat wing pan is better than the C6 pan. but the only real solution is a true dry sump, not the OEM "kind of" dry sump
Old 07-05-2012, 08:59 PM
6SPEEDZ
6SPEEDZ's Avatar
If it is for the car in your avatar you will be wasting your time with anything but a dry sump. Cars with aero need good oiling systems.
Old 07-05-2012, 09:38 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Call Gary at ARE. He can fix you up!
Jim
Old 07-05-2012, 09:59 PM
J.R.
J.R.'s Avatar
Default pan
Accusump with LS6 and batwing
Dry sump with LS2/ LS3
You may survive with Accusump LS2/LS3 but grip (A6's, Goodyear AC's), high rpm's and any aero exacerbates the issue.
Dry sump is expensive but what is an engine or crash worth.
Old 07-05-2012, 10:32 PM
mountainbiker2
that is the car.
Jim
ARE??
With an Accusump is there a kit you buy? I read some thing about manual or electric.
thanks,
Old 07-05-2012, 11:24 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Nope... C6 pan is worse. How'd you loose oil pressure auto-xing? Usually it's sustained high speed sweepers that hurt these motors. LS1/LS6s are quite robust. I've been racing mine over two years (3k miles @ 122k miles now) and never had oil pressure issues. I run a LS4 high volume pump and Amsoil 10w40 FWIW; no accusump.
Old 07-06-2012, 08:46 AM
mountainbiker2
Looks like I should stay away from the C6 pan. We had one left hand turn that my motor was around 6600 for some time. The shop where my car is, told me that it was from oil starvation. I just assumed that's what caused it. I've done many of these type of turns before. So really, I'm just guessing and maybe they are too.
Old 07-06-2012, 09:59 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
I suggest sticking with the stock LS6 pan or going to dry sump, and as mentioned in your other thread, for auto-x with aero, I'd consider a 30 grade racing oil.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 07-06-2012, 03:33 PM
gkmccready
gkmccready's Avatar
I think I have three years worth of data from Thunderhill in my '06 LS2 that clearly show oil pressure through T2, a sustained left-hand sweeper, getting lower and lower. If I overlay that with my terminal velocity on the front straight it also gets lower and lower.
This is a car with no aero, on 275+305 R888s, with coilovers & swaybars.
New motor went in last summer...
Old 07-07-2012, 09:41 AM
6SPEEDZ
6SPEEDZ's Avatar
You can find ARE at drysump.com. Using a accusump is a crutch that works for some. It will not work at some tracks. Tracks like Road Atlanta and Mosport will definitely have a problem along with Roval tracks. I personally know of more than a few aero cars that lost the engine at Road Atlanta and they had the LS6 pan and accusump.
Old 07-07-2012, 01:46 PM
J.R.
J.R.'s Avatar
by mountainbiker2
thanks,
Steve,
You can buy from Canton. I have used both manual and electric (on more recent cars).
One of the keys in making Accusumps more effective on LS engines is drilling the lifter trays and using restricted pushrods. I have had very good luck using an Accusump on LS6 and LS3 engines with using the above methods (i.e no blown engines). The main problem with LS engines, and more specifically LS2 and LS3, is oil pooling in the heads and upper portion of the engine.
This is also not to say that a dry sump is the real solution.
Old 07-07-2012, 02:27 PM
mountainbiker2
I ordered a Accusump. Seems like that should work for me. Seeing that I've gotten away this long with nothing. Thanks again.
Steve A.
To C6 oil pan vs. C5 oil pan??
Quick Reply: C6 oil pan vs. C5 oil pan??
