Go Back   Corvette Forum > General Corvette Topics > Autocrossing & Roadracing
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results Sponsored by
LG Motorsports
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-26-2012, 01:59 PM   #1
jd_black_00
CF Senior Member
St. Jude Donor '12, '14
Support Corvetteforum!
jd_black_00's Avatar
PandM_C6R
Default Front Tow Hook Dimensions?
Hi,
I was looking to build myself a front-mounted tow hook, but I'm not sure how long/wide it needs to be. Does anyone have dimensions that they used to make one? Also, what grade/alloy did you use?
Thanks!
jd_black_00 is offline   Reply With Quote
Old 06-07-2012, 01:29 PM   #2
waffle1971
Junior Member
waffle1971's Avatar
I am curious about this, as well. Also - where is the best spot to mount it?
waffle1971 is offline   Reply With Quote
Old 06-08-2012, 07:32 AM   #3
isnider
CF Senior Member
isnider's Avatar
I just ordered the OEM factory hook and bracket for the C6 Z06/ZR1, I'll take a pic and measure it when it gets here next week.
Ian
isnider is offline   Reply With Quote
Old 06-08-2012, 09:53 AM   #4
Z07coupe
CF Senior Member
Z07coupe's Avatar
I remember looking up the various regs on tow hooks when I was designing my C 4 front tow hooks. My tow hooks have an oval hole measuring 2" x 2.5". This oval hole (eyelet) is more than adequate for a hook or strap to be attached.
I still Have ready: C 4 front tow hooks, C 4 front cable guide (a different type of tow hook) and fire extinguisher mounts for C 4-5-6.
Z07coupe is offline   Reply With Quote
Old 06-08-2012, 12:31 PM   #5
Kubs
CF Senior Member
St. Jude Donor '09-'10-'11
Kubs's Avatar
kubs363 Kubs63
How much for a C4 front tow hook?
Kubs is offline   Reply With Quote
Old 06-08-2012, 12:59 PM   #6
TLGunman
CF Senior Member
TLGunman's Avatar
Certain sanctioning bodies have different dimensions, matl reqts. too, so you may need to check those if it matters.
TLGunman is offline   Reply With Quote
Old 06-10-2012, 09:43 AM   #7
Z07coupe
CF Senior Member
Z07coupe's Avatar
PMs sent.
Old 06-18-2012, 03:44 PM   #8
isnider
CF Senior Member
isnider's Avatar
Here is a pic of the factory C6 tow hook for european export
GM part number 10438557
It is roughly 7" long and the eye has an inside diameter of 1-5/8"
It costs around $30 from forum vendors
Click the image to open in full size.
Old 06-19-2012, 11:02 AM   #9
trapp
CF Senior Member
trapp's Avatar
Where does this insert? Is there any modification needed...I have a 2011 GS will it work for my car?
trapp is offline   Reply With Quote
Old 06-19-2012, 01:50 PM   #10
c4cruiser
CF Senior Member
c4cruiser's Avatar
I would like some info about the C4 hook and cable guide. Pics too if you have them. I have an 87. PM the info if you have a chance. Thanks!!
c4cruiser is online now   Reply With Quote
Old 06-19-2012, 06:52 PM   #11
isnider
CF Senior Member
isnider's Avatar
Quote:
There is a factory OEM bracket that has to be welded to the front cross member. Yes you have to remove the bumper but this is the only GM engineered solution and you don't have to cut any holes in the bumper or grill and the hook screws in and out.
The other aftermarket ones look like kinda of an after thought to me and I question their strength and practical use. The GM hook is forged steel and looks 4x the thickness of the popular aftermarket ones. The reciever bracket welded to the front cross member is steel for all C6's except the Z06/ZR1 that are aluminum billet for the aluminum frame.
Ian
Reload this Page Front Tow Hook Dimensions?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
