APR decklid mounted wing your experiences
Old 04-21-2012, 12:49 PM
Lawdogg
Lawdogg's Avatar
Default APR decklid mounted wing your experiences
Installed my GTC 500 with the provided mounting hardware. Anyone have experience with how the decklid will hold up on a high speed track like Road America? The metal backing plate looks sturdy, but I'm concerned about the decklid itself cracking.
Old 04-21-2012, 03:20 PM
meldog21
meldog21's Avatar
Good question. I'd like to know too since I just installed a GTC-300 last weekend.
Dog
Old 04-21-2012, 03:31 PM
GettReal
GettReal's Avatar
There are a couple guys I've seen that deck mount them and they seem fine hitting speeds up to 150+ at Mosport. I think they mounted them with plates on the bottom part of the deck. My guess though it also depends on the AOA you would use. With something aggressive and real high speeds, I might not mount that way.
Old 04-21-2012, 03:57 PM
mountainbiker2
mountainbiker2's Avatar
I would feel better if you did something like this. The bolts come up through the trunk lid. Plus, if you spin around backwards you would cause lift.
Steve A.
Old 04-21-2012, 08:50 PM
GT Racing Tires
Supporting Vendor
GT Racing Tires's Avatar
I had one of the first ones in the midwest (GTC 300). When I first bought it from Johnny at APR I told him my home track was Road America hitting 150+ three times every lap. I/we (friend also has one) had several problems but Johnny stood behind his product and replaced them every time.
No problems for a few years now! Very different product now from the original. If you don't use the plates that I believe are now provided with the wing you will crack your deck lid. We made our own since they were not originally provided.
Todd
GT Track Days at Road America June 11 & 12, 2012
www.GTTrackdays.com
Old 04-21-2012, 09:10 PM
TriplBlk
TriplBlk's Avatar
Dog
Is that a real carbon trunk lid or just vinyl?
Old 04-21-2012, 09:14 PM
Lawdogg
Lawdogg's Avatar
Thanks everyone!
Todd, with the aero and Continental slicks you just sold me, some good speed should be ahead for me at Road America. I feel better about running this wing now with your reply.
Old 04-21-2012, 10:11 PM
JDIllon
JDIllon's Avatar
I've been running mine for three years, Sebring, VIR, Homestead 155+ no problems. JD
Old 04-22-2012, 03:42 AM
meldog21
meldog21's Avatar
Its wrap. Way cheaper than painting the extra deck lid to match.
Dog
Old 04-22-2012, 10:36 AM
Z06Tracker
Z06Tracker's Avatar
Todd,
What mounting plates are you referring too? Is this a plate that mounts under the deck lid, or is is just the plates that go on top of the deck lid like the ones in the pics above? If it is something that goes under teh deck lid, anyone have pictures?
Old 04-22-2012, 11:27 AM
GT Racing Tires
Supporting Vendor
Originally Posted by Z06Tracker
Todd,
A plate that goes under the deck lid. Similar to the one on top. I used a 1" x 8" piece of aircraft aluminum. I am guessing on the size. My car is not here to measure. We also tapped another hole in the mounting bracket for three bolts per side.
Old 04-22-2012, 02:48 PM
dvandentop
dvandentop's Avatar
i can take pics of the metal plates.
i just installed mine yesterday as well
the metal plates will spread the load on the decklid and should be ok
Old 04-22-2012, 03:53 PM
RC45
RC45's Avatar
Good to see the APR wing get some good press. Mine has been mounted and idle since 2008 when I parked my car.
I guess my kit did not include the under lid plates.
I will get on the horn to APR to order a set.
Old 04-22-2012, 04:50 PM
GettReal
GettReal's Avatar
and thank you for sharing so many angles of the wing on a C5Z. Have been very curious of the sizing and how it looks. I assume thats the 300?
Old 04-22-2012, 08:21 PM
Z06Tracker
Z06Tracker's Avatar
Thanks. Please do.
Old 04-22-2012, 09:12 PM
sothpaw2
sothpaw2's Avatar
Anyone have any idea how much down force this would buy me at 75mph turn in speed? Are these street legal at all or do you just bolt them onto brackets in the lid at the track???
Andy
Old 04-23-2012, 12:41 AM
RC45
RC45's Avatar
Yes, it is the 300.
To APR decklid mounted wing your experiences
Old 04-23-2012, 10:48 PM
dvandentop
dvandentop's Avatar
look at the top 2 pieces to see those rear hatch pieces that go underneath to spread the load
Old 04-24-2012, 09:21 PM
Z06Tracker
Z06Tracker's Avatar
I talked tosomeoneat APR today. only the 500 model comes with the brackets that goes under the deck lid. the 500 was designed for the C6 which my contact says does not have as strong of deck lid compared to the C5. He said the 300 designed for the C5 and does not need the brackets under the deck lid.
Old 04-24-2012, 10:35 PM
travisnd
travisnd's Avatar
After seeing wings rip off on track I don't think I'd run with a decklid mounted wing. Whenever I get around to installing mine I'll be mounting to the rear bumper beam.
Quick Reply: APR decklid mounted wing your experiences
