Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Autocrossing & Roadracing
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results Sponsored by
PFADT Race Engineering
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-18-2011, 07:45 PM   #1
froggy47
CF Senior Member
froggy47's Avatar
Default c5 leaf springs stock z06 vs T1 ride height?
Is there an appreciable ride height difference? Thinking of trying some T1's I have.
Please don't side track into coils, thanks.
No "guesses" only post in if you have done it or have done some kind of measuring or analysis to back up.
Yes I know there are adjusters, just want to know what the spring will do to ride height, thanks!
I searched & did not find much.
__________________
2004 Z06/Z16 Stock motor, very modified suspension
1996 Black/gray LT4 Coupe (sold)
2007 328i (traded), 2004 IS300, 1995 M3 (sold), Chevy & Ford & Lexus SUV's.
'06,'09,'10,'11,'12 SCCA Regional Solo Champion
Life's too short for boring cars!
Click below for my DIY videos
http://www.youtube.com/user/1947froggy?feature=guide
froggy47 is online now   Reply With Quote
Old 12-18-2011, 08:31 PM   #2
redtopz
CF Senior Member
Support Corvetteforum!
redtopz's Avatar
Yes, the T1 springs allow you to lower the ride height much more than stock springs.
redtopz is offline   Reply With Quote
Old 12-18-2011, 08:45 PM   #3
froggy47
CF Senior Member
froggy47's Avatar
Old 12-18-2011, 09:37 PM   #4
gkmccready
CF Senior Member
gkmccready's Avatar
Send a message via AIM to gkmccready Send a message via MSN to gkmccready Send a message via Yahoo to gkmccready
Calculate it. You know corner weight, you know spring rates, ...
gkmccready is offline   Reply With Quote
Old 12-18-2011, 11:31 PM   #5
froggy47
CF Senior Member
froggy47's Avatar
Quote:
What I was wondering about is the natural (unweighted) curve of the c5z vs the t1.
And I'm not even sure it factors in to ride height, does it? Or is it just rate?
When I was changing springs on my 96 lt4 there was more than an inch height difference in the unweighted spring heights. There are dozens of different springs (factory & aftermarket) for the c4 & it was an ongoing discussion due in part to lack of information about which springs to use on c4's.
The t1 spring rates ARE higher RATED, but early indications are that the car sits lower on them. How can that be unless the unweighted curve also plays a part?
Old 12-18-2011, 11:36 PM   #6
gkmccready
CF Senior Member
gkmccready's Avatar
Quote:
Originally Posted by froggy47 View Post
The t1 spring rates ARE higher, but early indications are that the car sits lower on them. How can that be unless the unweighted curve also plays a part?
That question makes more sense to me now... the same question would apply to VBP vs stock springs since, IIRC, the VBPs are flat while the stock springs are all arch'd in some way...
Old 12-19-2011, 07:25 AM   #7
AU N EGL
CF Senior Member
AU N EGL's Avatar
When I made the change, the T1 set up was about 1" lower then then stock. Before corner weighting
AU N EGL is offline   Reply With Quote
Old 12-19-2011, 05:33 PM   #8
froggy47
CF Senior Member
froggy47's Avatar
Quote:
Thank you, my GUESSING is they are FLATTER when off the car, I will take a pic & measure them when I get to the change. It'll be easy enough to raise the car with the adjusters so this is a good thing.
Old 12-19-2011, 09:01 PM   #9
sperkins
CF Senior Member
sperkins's Avatar
Scott Perkins
T1 will probably be flatter. Here are some pics of a C5 ZO6 spring vs a C5 Z51 spring (rear).
Click the image to open in full size.
sperkins is offline   Reply With Quote
Old 12-19-2011, 09:16 PM   #10
froggy47
CF Senior Member
froggy47's Avatar
Thanks!
Old 12-19-2011, 09:17 PM   #11
redtopz
CF Senior Member
redtopz's Avatar
Yes, the T1 spring was much flatter than the stock spring when I compared them side to side.
However, I bought an old T1 kit off somebody else so maybe it was flattened out a bit when I bought it LOL.
Reload this Page c5 leaf springs stock z06 vs T1 ride height?
Tags
2003, adjust, c5, c6, corvette, height, hight, leaf, ride, spring, springs, stock, t1, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
