FS: Penske 8200 LE coil overs and Pfadt sway bars
I have a set of used Penske 8200 LE coil overs for sale. These are valved for street and track use. I also have a set of the heavy Pfadt sway bars for sale included as a kit.
This is a track-tested setup that ran 1:20.6 at Streets of Willow on a stock Z06.
Here's the writeup on the shocks from Gary at hardbar:
The Penske 8200 LE is a brand new shock system that uses all of the superb first class Penske 8700 3 way shock with a new internal separator piston to provide a low cost option. Hardbar and Leading Edge worked with Penske to offer this exclusive option. Now you can have the very best and upgrade as your needs and budget permit. This is an upgradeable system that has the capability of being easily converted to the 8300 2 speed or 8700 3 speed at a later time, by removing the separator piston and adding the hoses and canisters. All of the internal parts, and all of the best in class Hardbar mounts including the 17-4 PH "T" bar, the upper clevis mounts, and the adjustable rear lower clevis (shown in red anodized finish) are the same as the 8700 series. This shock has the best spring adjuster available on Acme threads as well. These are priced each and springs are optional as well. Suitable for leaf or coil-over applications. These are $550 each plus springs (if desired). As with all Hardbar products, they are 100% made in USA and each one is individually dyno'ed and you get the data files.
Price for 4 coil overs and Pfadt heavy sway bar kit = $1950
** As a bonus, this kit includes multiple spring rates/configurations at no additional cost.
