NEW - Quantum C6 Fog Light Brake Cooling Inlets
Old 08-19-2011, 02:01 PM
0Lambert_Automotive
Former Vendor
Lambert_Automotive's Avatar
Default NEW - Quantum C6 Fog Light Brake Cooling Inlets
We are proud to finally introduce our fog light inlet kit.
Move your brake cooling inlet where it should be, in the high pressure front bumper area.
Our kit is designed to replace the standard C6 fog light our inlets bolt right up to the factory fog light mounting points. The kit installs utilizing factory mounting hardware.
Special introductory price only $187.00!
Kit Features:
4" Diameter inlets for maximum flow.
TIG welded aluminum construction.
2 pieces of 4" I.D. flexible hose.
All necessary mounting hardware and instructions.
Note: This kit will require some minor trimming of your inner fender liner.
Some pictures:
Please go here to place your order:
C6 FOG LIGHT INLET KIT
NOTE: This kit is currently in production. Please allow 2-3 weeks for delivery.
Old 08-19-2011, 03:24 PM
naschmitz
naschmitz's Avatar
This looks great!
Old 08-19-2011, 03:36 PM
LeMans05C6
LeMans05C6's Avatar
I think I am going to have to add these to my wish list for my brake cooling upgrade package. The air from the front with good ducing to the rotors sounds like some cool brakes to me!
Old 08-22-2011, 04:12 PM
C&M Racing
C&M Racing's Avatar
Has any wind tunnel type testing been performed on if there is an advantage getting air from the front bumper vs the under the bumper inlet? I would assume you could put one of each on a car with a pressure gauge to determine which is better. Wind tunnel would be better but not in most peoples budget and I don't think work would like me bringing a race car to their tunnel. If I worked in the tunnel I might try it but I do like the money from my job....
Old 08-22-2011, 06:48 PM
0Lambert_Automotive
Former Vendor
For a lower volume product like this it simply is not economical to wind tunnel test.
There is a distinct advantage to moving the intake from the low pressure area under the bumper to the high pressure fog light area. Michelin verified this with their independent testing of our earlier version of these inlets, and we have seen good results using the system on our car.
The results showed peak rotor temperatures reduces by approximately 30%.
Old 08-22-2011, 08:29 PM
DC321
DC321's Avatar
Looks like a great idea and great execution. Good luck.
Old 08-22-2011, 09:48 PM
dvandentop
dvandentop's Avatar
if they worked good @ road america yesterday and saturday that is good enough for me!
Old 08-23-2011, 12:42 PM
0Lambert_Automotive
Former Vendor
They worked quite well at RA. In fact I had more brake than tire, and I am running OE Z06 calipers with Cobalt Friction pads and DBA rotors.
Old 08-23-2011, 01:40 PM
tomiboy
tomiboy's Avatar
Do you have any installation instructions on your website? I'd like to see what is involved
These reduced peak rotor temps by 30% from what...no ducts or your original ducting
Old 08-23-2011, 04:03 PM
0Lambert_Automotive
Former Vendor
The kit is still in production so I have not completed the installation instructions yet, however the installation is quite simple.
Here are the basic steps:
Remove the front inner fender liners
Remove and trim the Z06 inlets (so that the 4”hose can be attached)
Remove the fog lights and install our fog light inlets
Install the 4” hose and Z06 inlets
Trim the fender liner to clear the new position of the Z06 duct (the top edge of the existing opening needs to be opened up)
Re-install the fender liner
They reduced from OE ducting inlet location under the car, i.e. the low pressure area. The car tested was equipped with our spindle duct kit for both tests.
Old 08-23-2011, 05:37 PM
Charley Hoyt
Charley Hoyt's Avatar
Another great product....now how am I going to explain this one to my wife.
Old 08-23-2011, 05:42 PM
dvandentop
dvandentop's Avatar
now if someone would just sell me these at a reasonable cost
Old 08-23-2011, 09:51 PM
db2xpert
db2xpert's Avatar
Don't let her get under the car to see it...
Old 08-31-2011, 07:45 PM
0Lambert_Automotive
Former Vendor
For those that place their order through the end of next week I will include free of charge aluminum wire mesh covers. Those that have placed their orders already will also receive the covers free of charge.
Picture of the inlets with the covers on a base C6 bumper at the track:
You can see how inconspicuous they look with the covers installed. (above on the left) This picture was taken while we were evaluating the difference in cooling from the OE under bumper position to the fog light position. (note the fog light still in place above on the right)
Pictures of the inlets with the covers on the Z06/ZR-1/GS bumper:
Finally a picture off the car:
Old 08-31-2011, 08:20 PM
Charley Hoyt
So you did the cooling evaluations (30% improvement)with screens on?
Old 08-31-2011, 08:28 PM
0Lambert_Automotive
Former Vendor
Yes sir.
Old 08-31-2011, 09:34 PM
Charley Hoyt
Yes sir.
Fantastic result
To NEW - Quantum C6 Fog Light Brake Cooling Inlets
Old 09-01-2011, 01:43 PM
tomiboy
tomiboy's Avatar
Ordered!
Old 09-02-2011, 10:40 AM
taken19
Track Junky
taken19's Avatar
Can you give an estimate of cooling effect of a stock base C6 setup to your under the car (low pressure area) configuration? It would give everyone an idea of all options available and their effect on brake cooling. I just ordered the non foglight touring kit because I don't track much just yet.
Providing a baseline and all available options will help drivers determine their best option based on driving habits.
Thanks for a great product!
Sean
Old 09-02-2011, 12:28 PM
0Lambert_Automotive
Former Vendor
Sean
I never did a baseline check for the stock C6 (dump into the wheel well area) cooling. I suppose I could do this, but I am not sure how soon I would be able to make it happen. I would also have to rig something up as I no longer have any of the OE C6 brake cooling hardware laying around. So technically it would not be apples to apples.
Quick Reply: NEW - Quantum C6 Fog Light Brake Cooling Inlets
