Causes for high oil temps?
My car has started to spike oil temps quickly. With my oil cooler I used to never see above 250 but now it is hitting 270-280 in a couple laps.
Does not consume a lot of oil on a track weekend and I am not getting much in the catch can. Water temps are 221 or so. \\
The cats checked out, the Tech II said I had fuel and spark and I could pass emissions. Diagnostics showed nothing and we checked everything. All I have is a idle that hunts from 600-800 rpm and motor, power wise, that feels like it is running on 6 cylinders.
Leakdown and compression checked out a few months ago. It has a forged bottom end and maybe 5000 gentle track miles on it.
Heat in oil comes from friction and/or combustion gases in crankcase in my experience.
Any thoughts?
Any thoughts?
quoted from another thread:
Yes. I remember doing searches on this--around 265 oil was as high as guys had it on a regular basis and still had long engine life. Definitely need coolers--they will help your lap times too. A cooler motor makes more hp/tq.
Andy
Andy
I'm with Sidney on this one. What is the weight of the oil? The weight of the oil makes a real difference in oil temps. I got a significant drop in temps once I went to a 5W-30.
btw - My latest Vintage Motorsport column (which I haven't posted on my web site yet) deals with engine coatings. Coatings are a huge deal in F1 and NASCAR. When you're looking for those last 5 bhp you're going to get involved in coatings.
Richard Newton
Newton's Law in Vintage Motorsport Magazine
Richard Newton
Jeffro, as someone earlier wrote, clean out the cooler fins. You'll probably have to dismount it so you can get in behind it real easily, but I'd eliminate that first as the problem.
If it is down on power noticeably and not from really high ambients temperatures and spiking oil temperatures like that, I would be cutting the oil filter apart and making sure that nothing bad is about to happen.....
Tech-II passed and did not show engine missing which I think is P300.
Car is not missing but feels low on power.
Oil temps increasing.
First thing I would do is pull spark plugs and use a torque wrench to see how hard the engine is to turn over. I am sure others can give you a ball park of how much drag is in a good moter. If drag is up look at bottom end. I record drag when engine is built and can compare with later test.
Basic increased oil temps means more friction. This assumes nothing else has changed in the cooling system and coolers are not dirty.
Send the oil off to be analyzed and cut the filter open.
If the car is living at high RPM ......... a dyno pull will tell you if you are down on power. Ours was down 35hp........freshened the heads and back to 390rwhp we went. Its all about the valve springs........
"My car has started to spike oil temps quickly. With my oil cooler I used to never see above 250 but now it is hitting 270-280 in a couple laps."
