Go Back   Corvette Forum > General Corvette Topics > Autocrossing & Roadracing
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results Sponsored by
LG Motorsports
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 07-20-2011, 11:07 AM   #1
ptindall
CF Senior Member
ptindall's Avatar
Location: Catching tuxnharley lying, making him cry, and telling the world how slow his Volt is until he puts me on his ignore list.
Default Wheel balance weights falling off?
After one track day I put my new set of wheels and tires back in my garage only to find several weights falling off. These are the stick on weights inside the barrels. So I cart them all off the the tire shop, they tell me all four wheel are out of balance. I ask why the weights are falling off. They say, "you are getting the wheels really hot and melting the glue. When they cool, they fall off. Put duct tape over the weights to hold them on."
This is all news to me. What is everyone else doing?
ptindall is offline
Old 07-20-2011, 11:09 AM   #2
Jason
CF Senior Member
CI 4-5-6-7 Veteran
Jason's Avatar
Metal tape.
Jason is offline
Old 07-20-2011, 11:38 AM   #3
charger21
CF Senior Member
charger21's Avatar
Tom Reis
New wheels need the barrels wiped down with a alchol pad. They put something on them to protect the finish when they are new. I have ran into this several times. Wipe them down and you should be good to go!
charger21 is offline
Old 07-20-2011, 11:38 AM   #4
VetteDrmr
CF Senior Member
VetteDrmr's Avatar
I've used both duct tape and aluminum tape with good results.
Frankly I've stopped balancing my track wheels. Tires move on the wheels, weights slip/go away, etc. Plus I'm not that concerned about tire vibrations on the track compared to the street. Especially for autocross wheel balancing just isn't that noticable.
Even for DEs I don't feel any vibrations. Not saying they aren't there, just that they're way outside my attention zone.
HTH, and have a good one,
Mike
__________________
1 of 189 2000 Nassau Blue Metallic FRCs, born on December 1, 1999, adopted June 14, 2002
HUD, AH, 260,000+ miles, shortened stock shifter, LG Street LTs + Z06 Ti mufflers
VetteDrmr is offline
Old 07-20-2011, 11:53 AM   #5
AU N EGL
CF Senior Member
AU N EGL's Avatar
HVAC Aluminum duct tape
AU N EGL is offline
Old 07-20-2011, 12:01 PM   #6
Joe_Knesek
CF Senior Member
Joe_Knesek's Avatar
has anyone used dynamic wheel balancing beads? I'm not sure if they work well at high speeds but some of my customers have used them on truck wheels.
http://callieskustoms.com/CalliesKus...g%20Beads.html
Joe_Knesek is offline
Old 07-20-2011, 12:11 PM   #7
Feffman
CF Senior Member
Feffman's Avatar
Per a post or two up, make sure the person balancing the tire cleans the area where the stick-on weight is to be applied. I've used the black "Gorilla Tape" available at Home Depot, Lowes, etc. and have never lost a weight.
Feff
Feffman is offline
Old 07-20-2011, 12:27 PM   #8
ptindall
CF Senior Member
ptindall's Avatar
Quote:
Sorry for the confusion. My wheels were not new, they were new to me. They had just been refurbed and powercoated when the weights were applied. They had zero miles on them since powdercoating. They were clean at the time but I doubt they used alcohol or acetone before appling the weights.
Thanks for the confirmation that I'm not alone and tape is the correct solution everyone.
ptindall is offline
Old 07-20-2011, 12:38 PM   #9
Black89Z51
Suckin' gas, haulin' ass.
Support Corvetteforum!
I've mounted hundreds of tires for guys at the track. I use the stick on weights from NAPA and aluminum tape. Make sure you clean the wheel off where are you putting the weight and tape with some brake cleaner. I've never had a single weight fall off.
Black89Z51 is offline
Old 07-20-2011, 01:15 PM   #10
froggy47
CF Senior Member
froggy47's Avatar
Aluminum tape, and mark the tire to see how much it moves. I reverse the direction each event & they usually move back about the same amount.
I also mark the weight locations so if I throw one I can just replace it.
YMMV
__________________
2004 Z06/Z16 Stock motor, modified suspension
1996 Black/gray LT4 Coupe (sold)
2007 328i (traded), 2004 IS300, 1995 M3 (sold), Chevy & Ford & Lexus SUV's.
'06,'09,'10,'11,'12,'13 SCCA Regional Solo Champion
Life's too short for boring cars!
Click below for my DIY videos
http://www.youtube.com/user/1947froggy?feature=guide
froggy47 is offline
Old 07-20-2011, 01:53 PM   #11
Bill Dearborn
Bill Dearborn's Avatar
It also depends on the brand of stick on weight they use. Since the use of stick on weights has increased a lot lately this is less of a problem because most tire shops are now using quality weights. However, in the past I have been to stores that used the cheap weights and they fell off the rims when I pulled into the garage after driving home.
Bill
Bill Dearborn is offline
Old 07-20-2011, 05:13 PM   #12
Joe_Knesek
CF Senior Member
Joe_Knesek's Avatar
FYI, acetone will damage powdercoating. Denatured alcohol should work fine.
Old 07-20-2011, 05:46 PM   #13
froggy47
CF Senior Member
froggy47's Avatar
In Kali the Enviro's have all the tire places switch from lead weights to steel weights & they are a little bigger dimension for a 1/4 oz. I seem to find more getting loose than the old lead ones, hence every one gets alum tape.
Can't get decent brake cleaner spray either, the stuff the sell now works about as good as maybe windex.
froggy47 is offline
Old 07-20-2011, 10:43 PM   #14
UstaB-GS549
CF Senior Member
UstaB-GS549's Avatar
Walmart used to clean my wheels with alcohol before sticking on weights. No tape. It is fairly difficult to get them off when changing out tires. In fact it is a PITA to remove all the adhesive. If Walmart can make them stick... it's not rocket science...
Lately I have stopped bothering with balancing and cannot feel the the difference even at Road America. When you consider that the tires slip a little on the rims and that big hunks on track turds end up on the inside of the rim or stuck to the tread, I kind of think balancing may be in vain.
Just another opinion.
UstaB-GS549 is offline
Old 03-05-2013, 10:09 AM   #15
me46328
Junior Member
Maybe too late reply, but might be useful for others that have some trouble.
Check the dyne of the rim surface (Surface tension energy).
Stick-on weight should be small facet.
However, check to other possibility factors
Shelf life of adhesive must not over than 1 year.
Application method should provide at least 1 kg/cm2 force applied.
me46328 is offline
Old 03-05-2013, 11:16 AM   #16
JimTN
Moderator
JimTN's Avatar
Please don't revive 2 year old threads.
http://forums.corvetteforum.com/foru...s-or-more.html
JimTN is offline
Reload this Page Wheel balance weights falling off?
Closed Thread
Tags
balance, balancing, coming, falling, falls, fell, forum, racing, rims, stick, tape, tire, weight, weights, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
OEM Wheel Weights for Magnesium Wheels? wjsullivan C5 General 8 05-29-2013 09:37 AM
removing wheel weights dckotwicki C6 Corvette General Discussion 5 05-01-2013 08:54 PM
GS wheels vs Cup wheels Cyber Greg C6 Corvette General Discussion 17 10-21-2012 12:43 PM
Discount Tire paguru C6 Corvette General Discussion 29 10-20-2012 02:38 PM
Tire Balancing larryfs Autocrossing & Roadracing 2 09-26-2012 07:50 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
