Square TIRE, Nitrogen, Dry Air etc
just "vacuuming" a tire to diagnose and repair a leak around the bead. Thought I'd snap a photo to show what many of the Pro teams used to do to get all of the excessive moisture out of the tires before filling with nitrogen or "dry" air. Not trying to start another debate over what kind of gas to use, just showing a picture if anyone cares.
This is a c6Z06 rear wheel/tire
Something about a square peg and a round hole come to mind when I see that picture.
The Porsche guys invite "volunteers" to help at the races..... They get to Vacuum the tires, and they get to clean out the holes drilled in the rotors. Good times!
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Ive had tires like that before. For different reasons though... Since driving a car with ABS it hasnt happened.
It also maintains the pressure as to not build up as much.
With a relative humidity gauge, I was getting 25-30% moisture from regular air and after purging and filling with nitrogen it dropped to 3-5%.
Good stuff David!
We did this for all the teams when I worked in ALMS. Works great!
Good stuff David!
Good stuff David!
That stuff really works wonders to keeping the pressures stabilized when temps go up and down.
Good stuff for sure
At my last race, I was bleeding pressure off my tires and water was literally blowing out of the valve . It's been a foggy damp winter here and they were probably filled on a cold humid day... I think I will bleed them down and fill with dry air/nitrogen. Thanks David for the reminder.
A tip for those of you that dont have nitrogen at your disposal! Make sure you drain your compressor of moisture often and upgrade to a good inline filter system to cut down the moisture.
I bought roughly a 36" tall nitrogen tank from a local welding shop supply store and the regulator with flexible yellow hose. I then went to sears and bought the $19.99 mini portable fold up dolly and ratchet strapped the tank to it.
I probably have $300.00 in the whole set up but when I want to exchange the tank, it is only $20.00. This was also used to check and set my Moton triples at the track as they can slowly bleed down over time.
Something to look into for all you track junkies.
Aaron
Aaron
Aaron
Aaron
For a whole season in 09 doing 4 sets plus my shocks all year long. Plus I still have some left.
