Lexan rear window for a C5 Z06?
Old 01-09-2011, 09:55 PM
mountainbiker2
mountainbiker2's Avatar
Default Lexan rear window for a C5 Z06?
Is there anyone selling these for a C5 Z06?
thanks,
Steve A.
Old 01-09-2011, 10:11 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I got my World Challenge lexan from this company. I know they have Z06 rear, not sure about coupe
http://www.racingshields.com/default.html
Old 01-10-2011, 12:13 AM
mountainbiker2
I have a FRC. I'll give them call.
thanks,
Old 01-10-2011, 12:17 AM
gkmccready
gkmccready's Avatar
http://www.summitracing.com/search/b...9/?Ns=Rank|Asc
Percy's SpeedGlass. http://www.percyshp.com/SpeedGlass.html http://www.percyshp.com/store/speedglass/cat_8.html
Just another alternative.
Old 01-10-2011, 12:23 AM
mountainbiker2
What thickness do we get for the rear? How do we install this? As you can see, I want one, but know nothing about it.
Steve
Old 01-10-2011, 03:06 AM
gkmccready
gkmccready's Avatar
In the SCCA GCR they say 6mm (1/4") for the windshield, and 3mm (1/8") for the rear or side windows -- it seemed consistent across at least GT, ST and Prod. The NASA CCR says 3/16" for the windshield and doesn't specify for anything else that I can see.
There're a bunch of ways to install it depending on what you order and what you want. You can use adhesive like the stock windows, or fasteners. On some vehicles you can replace the entire `frame' or hatch with just the polycarb to save even more weight... not useful to your FRC, I don't think...
Old 01-10-2011, 08:07 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Steve
you can bolt it in with SS countersunk flat heads and counter suck conical washers.. My rear hatch is 3/16" on my coupe which is a lot bigger than you Z
Old 01-10-2011, 08:17 AM
bosco022
bosco022's Avatar
Five Star Race Car bodies makes them for both C5 & C6 Vettes.
We bought ours there, competitive pricing
Old 01-10-2011, 09:38 AM
mphox
mphox's Avatar
Anybody have Any pics or links to installation methods?
Old 01-10-2011, 10:11 AM
davidfarmer
Just bolt or rivet the rear in. For the front you will need reinforcement....I made aluminum channel
Old 01-10-2011, 10:46 AM
brkntrxn
brkntrxn's Avatar
What kind of weight savings are we talking about? Windshield and rear glass on a Z06/FRC?
-Kevin
Old 01-10-2011, 01:59 PM
John Shiels
you will have to trim the lexan to fit it is not an exact copy of your glass.
Old 01-10-2011, 02:08 PM
John B
Pro Mechanic
John B's Avatar
I had 1 of my guys make 3. I think he messed up the first 1 . He said it was easy. I'll ask him tonight as he no longer works for me.
Old 01-10-2011, 02:09 PM
geerookie
geerookie's Avatar
-Kevin
I don't know specifics for a Z06/FRC but on the coupe I saved 27lbs.
Old 01-10-2011, 02:17 PM
geerookie
geerookie's Avatar
These things are usually very expensive 350$ or more
I made my own. $83 and that was for a coupe. Z06 would be less.
Before I removed the rear glass I made a template using butcher paper.
Then went to my favorite hardware store and bought a sheet of 3mm/1/8" Lexan and cut it out from my template with a jig saw.
As John said, do a little trimming and it's a perfect fit.
I riveted mine in. Lighter than using any other type of fastener.
Old 01-10-2011, 07:36 PM
mountainbiker2
I ordered one from Racing Shields. The company "DavidFarmer" recommended. 1/8" cut to fit. They were very helpful on the phone. Should have it in a couple of weeks. I'll let you guys know what happens.
thanks,
Steve A.
Old 01-10-2011, 07:42 PM
drivinhard
drivinhard's Avatar
IIRC OEM C5 front glass is ~36 lb, Z06 is 30 lb, rear Z06 is ~20 lb
To Lexan rear window for a C5 Z06?
Old 01-23-2011, 06:36 PM
davidfarmer
how hard is it to heat/bend lexan???? I've never tried it. I know the Shields winshields can be purchased with chip and fog protection, but for the rear who cares.
Old 04-05-2011, 12:48 AM
travisnd
travisnd's Avatar
Bump... the idea of getting a sheet of lexan for the rear from the hardware store and cutting it to fit has my attention. When installing with a rivet is there any worry about cracking the plastic? Any tips?
Old 04-05-2011, 04:15 AM
trackboss
trackboss's Avatar
Yes. Whatever method you choose to install allow the piece to float somewhat.
Quick Reply: Lexan rear window for a C5 Z06?
