Go Back   Corvette Forum > General Corvette Topics > Autocrossing & Roadracing
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results Sponsored by
LG Motorsports
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-18-2010, 11:58 AM   #1
TS Motorsport
CF Senior Member
TS Motorsport's Avatar
TrackstarMotorsport TSmotorsport
Send a message via AIM to TS Motorsport
Default Comp cams LSR cam for road racing
Does anybody have the LSR cam on their C5 Z06 who road races?
There are two LSR cams I am curious about. The cam will be installed with all the necessary parts including the 921 kit, mellings oil pump, ARP damper bolt, new seals, gaskets, etc.
The first being the LSR 54-457-11, the specs are.
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 1,700-6,800
Intake Duration at 050 inch Lift 223
Exhaust Duration at 050 inch Lift 231
Duration at 050 inch Lift 223 int./231 exh.
Advertised Intake Duration 273
Advertised Exhaust Duration 281
Advertised Duration 273 int./281 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.610 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.617 in.
Valve Lift with Factory Rocker Arm Ratio 0.610 int./0.617 exh.
Lobe Separation (degrees) 112
Camshaft Gear Attachment 3-bolt
Computer-Controlled Compatible Yes
The second one being the more likely of the two.
LSR 54-456-11
Basic Operating RPM Range 1,500-6,700
Intake Duration at 050 inch Lift 219
Exhaust Duration at 050 inch Lift 227
Duration at 050 inch Lift 219 int./227 exh.
Advertised Intake Duration 269
Advertised Exhaust Duration 277
Advertised Duration 269 int./277 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.607 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.614 in.
Valve Lift with Factory Rocker Arm Ratio 0.607 int./0.614 exh.
TS Motorsport is offline   Reply With Quote
Old 11-18-2010, 08:43 PM   #2
AU N EGL
CF Senior Member
AU N EGL's Avatar
Stock cam for most racing. T1 or NASA ST2
or the GM Cup Cam for World Challenge or SPO
AU N EGL is offline   Reply With Quote
Old 11-19-2010, 03:32 PM   #3
TS Motorsport
CF Senior Member
Is the GM cup cam the same as the GM PP asa cam?
Old 11-19-2010, 07:26 PM   #4
AU N EGL
CF Senior Member
AU N EGL's Avatar
No two different cams
GMPP ASA 226/236 525/525 110
GM- Grand am cup 239/251 570/570 106
Old 11-22-2010, 01:35 PM   #5
TS Motorsport
CF Senior Member
Thanks for that info.
Reload this Page Comp cams LSR cam for road racing
Tags
269, 277, 5445711, asa, cam, cams, camshafts, comp, corvette, cup, duration, gm, gmpp, lsr, racing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
