Katech-powered Corvette sets GT car TRACK RECORD at Paul Ricard
Old 09-16-2010, 09:29 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default Katech-powered Corvette sets GT car TRACK RECORD at Paul Ricard
C5 Corvette with Katech Track Attack LS7. Horsepower undisclosed
__________________
Contact:
(e) zach@katechengines.com
Old 09-16-2010, 10:25 AM
95jersey
95jersey's Avatar
Nice, good job boys!!
Love that track. TONS of run off (like an F1 course) to let it hang out. European tracks are so much nicer than the US tracks.
Old 09-16-2010, 11:15 AM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
What tranny is he running and is it a paddle shift or left hand shift? Almost sounds continuous?
Old 09-16-2010, 11:47 AM
Katech_Zach
Weismann paddle shift
Old 09-16-2010, 11:52 AM
AU N EGL
AU N EGL's Avatar
Very Cool
Old 09-16-2010, 12:30 PM
Katech_Zach
Pics
Old 09-16-2010, 12:36 PM
Katech_Zach
Official record 2:09.734
http://www.circuitpaulricard.com/Use...ts%20total.pdf
Page 2, competitor #33, car #102, Owner Benton Bryan, Driver Nigel Greensall
Old 09-16-2010, 01:17 PM
Kubs
Kubs's Avatar
Received 1,753 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Sweet! Is that built on a GT1 chassis?
Old 09-16-2010, 01:34 PM
Katech_Zach
No, tube frame.
Old 09-16-2010, 01:41 PM
95jersey
95jersey's Avatar
Originally Posted by Katech_Jason
Pics
wow, look at those intake runners, talk about high RPM.
Old 09-16-2010, 01:57 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
that is one hot car
Old 09-16-2010, 03:20 PM
AU N EGL
AU N EGL's Avatar
Carburetor.
Mega ponies I bet
Old 09-16-2010, 03:26 PM
Katech_Zach
Originally Posted by AU N EGL
Carburetor.
Mega ponies I bet
No carburetor. Kinsler 1000cfm throttle body and MEFI system.
Old 09-16-2010, 03:28 PM
wallyman424
wallyman424's Avatar
Yup. For fun (and i repeat FOR FUN), i've been reading about intake runner length. There are actually a lot of strange options available for lsx motors out there.
Old 09-16-2010, 03:42 PM
63Corvette
63Corvette's Avatar
I concur However, isn't that a Victor Jr (tarrantula type) individual runner manifold (intended for a carb) developed for NASCAR Daytona type tracks. Kinsler has forgotten more about Electronic FI than most will ever know.
Old 09-16-2010, 03:45 PM
Katech_Zach
It is a GMPP manifold for carb or FI.
Old 09-16-2010, 05:15 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Looks like there ought to be some way to shoe-horn that intake/TB under my hood.
To Katech-powered Corvette sets GT car TRACK RECORD at Paul Ricard
Old 09-16-2010, 06:48 PM
VanSpeed
VanSpeed's Avatar
Now then one can only image what the possibilities would be for the GT1 C5R/C6R LS7 if they would have been allowed to run unrestricted. Just think of the fun it would have been to watch an unrestricted GT1 C5R/C6R run down the long straights of LeMans with Ferrari and Austin V12s also unrestricted. Did Katech ever play around with unrestricted set ups or just make by the rule book, no time to play? Thanks for sharing.
Brian
Old 09-17-2010, 08:40 AM
Katech_Zach
Brian
No, we have not. Parts were designed around the restrictor. Once a restrictor goes sonic you're not going to get any more air and therefore no more power. Because of this, cylinder head ports and intake runners were designed to maximize torque. Simply removing the restrictor will not yield huge power increases. If you ran a different cylinder head and intake manifold it would, but the bottom end was designed to be lightweight and durable at 580hp so the whole engine would need to be re-tested for durability at higher power levels.
Old 09-17-2010, 09:35 AM
VGLNTE1
VGLNTE1's Avatar
if the motor was developed for maximun TQ, why did you use the square LS7 type head over a cathedrial port? every test ive seen still shows that type as making more mid range TQ
Quick Reply: Katech-powered Corvette sets GT car TRACK RECORD at Paul Ricard
