New Hardbar/AP T1 brake kit!
1 Post
Cruise-In II Veteran
We are very proud to introduce the new Hardbar/AP Racing T1Corvette brake kit. The kit is compliant with SCCA T1 rules and will fit most wheels (CCW Classics excepted). It uses the very best technology and components available anywhere. The caliper is a super stiff, forged aluminum competition design with many details that you will not find on a street based caliper, like nerf bars to prevent the bleeders from getting knocked off in wheel changes. The caliper is a new version of the AP 8350 4 pot and has stainless steel pistons with anti-kickback springs. This caliper is a based on the caliper that is used in NASCAR Featherlight Modified series, only is a radial mount and has the appropriate piston sizes for the OE Corvette master cylinder. The pads are the 7420 (20mm thick!) shape which are available in virtually any compound, from soft street pads to the CL RC8 pads used to win at the highest level of NASCAR road race competition. We will be offering several pads for this as well, such as the CL RC8 and the Ferodo DS1.11 (to mention only 2)
See the following link for additional details:
http://www.essexparts.com/shop/compe...0-caliper.html .
The rotor is a 12.81 diameter, 1.25 thick, 70 vane, "J" hook rotor, that is a full floating design on Hardbar hats. The Hardbar hats (all production hats are black hard anodized, as shown in the video) have many unique innovations from the captured fasteners, to the air bypass ports that allow airflow to the outer face of the rotor that normally never gets the benefit of the cooling air. The captured hex head AN (aircraft) fasteners not only do not have the possibility of rotating, but they aid in rapid rotor ring changes. We use Nordlocks on the nut side for the ultimate in security. All this and it still 2 pounds lighter than stock/NAPA rotors!
We made a short video to show the procedure for assembly of a replacement rotor and please note the air bypass ports on the hat at the end of the video.
http://www.youtube.com/watch?v=UIqwEDgw5U0
Replacement rings are only $250 and as compared to the NAPA stock rotors, you will not know how to occupy your time at the track, since you will not be replacing these very often! Over the next few days, we will add to this thread, but I wanted to get the announcement before we leave for 2 days. It is available for ordering now, with shipping to commence next week, $2600 for the whole front end, pads and SS lines additional.
http://hardbarusa.com/hardbar/produc...roducts_id=156
In addition, we will also be offering a Quantum Motorsports brake duct kit that is specifically designed for this brake system and does not require wheel bearing removal (gotta love Solidworks and the ability to swap models!)
1 Post
Each. The rotors are available separately. They will not fit the OE slide rail calipers, but will fit most any 4 or 6 pot aftermarket caliper.
Complete rotor assembly:
http://hardbarusa.com/hardbar/produc...roducts_id=154
Replacement rings:
http://hardbarusa.com/hardbar/produc...roducts_id=155
Replacement rings:
Supporting Vendor
I think you guys are really going to like this kit. I've spent quite a bit of time over the past few days pulling these calipers apart, taking photos, etc. They have an unbelievable amount of content in them for the money. There isn't anything else built to this spec on the market.
These discs are also tanks. I know a few of you T1 guys have been thrashing them, and I'm sure you're finding that they're bullet-proof. We've been torture testing them in pro racing for a long time, so I know they will be able to take any abuse you throw at them.
Nice work putting this thing together Gary. This is one serious package for the money.
I gotta have some of that...
Gary,
What a great package. I am a novice to HPDE but have quickly learned that the brakes are the weakest link on my car. I have spindle ducts and have been running Cobalt CSR pads but can still get a soft pedal after a hard 30 minute session. Your seat rails, camera mount, and Delrin shift **** (I have) are great products and I appreciate your willingness to explain a few things to me via telephone. Keep up the good work bringing useful products to market.
Jim
Jim
I have been very impressed by the durability of the rotors. I won't know what to do if I don't have to be checking and replacing rotors between practice, qualifying and race sessions.
Maybe I will have to buy a lawn chair for the paddock.
Oli
easy ring swap looks great! Losing 2 pounds per wheel. is great also
that is also a good link you have http://www.essexparts.com/shop/compe...0-caliper.html .
7420 is a very common pad which is used in the Wilwood SL-6
Are they running these front & rear with smaller pistons in the rear?
1 Post
Yes, but it might require some shimming/trimming of the WW brackets. And yes John, it is a USA/UK project, just like the P-51 Mustang!
I want my APC (AP calipers)
Supporting Vendor
