C5ZO6 Roll Cage Completed!
Old 03-02-2010, 10:11 PM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
Default C5ZO6 Roll Cage Completed!
I would like to thank Jerry Onks of VetteSport for the VetteSport Roll Cage, and Chuck Yoder of Yoder Tool for the fabrication and painting of the Roll Cage, both of Smyrna Tenn. They have done an excellent job on my car! I can't wait to get my car back to finish up some details. Hopefully my first event this year will be at Barber Motorsports Park the end of March. Did I mention I like RED?
Old 03-02-2010, 10:17 PM
davidfarmer
davidfarmer's Avatar
damn that's a LOT of bars........you doing freestyle ski jumping at the next olympics???
Great looking welds!
Old 03-02-2010, 10:20 PM
drivinhard
drivinhard's Avatar
Only C5Z in the world with a 45F/55R weight split, wow that's a lot of steel back there
got a better shot of the dash bar (from A pillar to A pillar?)
Old 03-02-2010, 10:42 PM
BERETTA
BERETTA's Avatar
No ski jumping in my future! However the cage may be strong enough too! Thanks...
Old 03-02-2010, 10:52 PM
ZO6NTHEWIND
ZO6NTHEWIND's Avatar
He's so slow..... he needs protection from the cars running over his slow a$$
Thanks for all the help with my seats, Dennis. Let me know when you pick up your car.
Old 03-02-2010, 11:05 PM
BERETTA
BERETTA's Avatar
I guess I could add some ballist up around the radiator
This is the best picture I have of that bar right now..
Old 03-02-2010, 11:16 PM
BERETTA
BERETTA's Avatar
Thats the truth! Maybe with all this extra protection I will pick it up a little bit! The new sways, poly bushings, coil overs, and Kumho 710's will help too
Your welcome! They look great!
Old 03-03-2010, 01:26 PM
Han Solo
Han Solo's Avatar
Good looking cage but from a rules standpoint I'm not sure if the diagonal brace will be legal.
NASA CCR:
15.6.7 Diagonal Brace
One (1) diagonal brace shall be used in the same plane as the main hoop. The diagonal
should be one continuous path; meaning that it must conform to Diagrams 15.6.7a or
15.6.7b. Note- If the installation method from Diagram 15.6.7b is used, the builder
should pay close attention to alignment. One end of the diagonal brace shall attach to
the corner, or horizontal part, of the main hoop above the driver’s head, within twelve
(12) inches of the driver’s-side corner.
The other end of the diagonal brace shall attach
to the mounting plate (or to the main hoop as close to the mounting plate as practically
possible) diagonally opposed to the driver’s head (passenger floor).
Old 03-03-2010, 03:34 PM
Z06Norway
Z06Norway's Avatar
Default wow, safety first i guess
how much weight is your cage ?
lets hope you never have to test the strenght
Rune
Old 03-03-2010, 03:49 PM
Dave Deerson
Dave Deerson's Avatar
Could you post a pic of the base of the main hoop and how it ties in with the frame??
Old 03-03-2010, 10:20 PM
svcjmo
svcjmo's Avatar
I assure you this cage will pass any sanctioning bodies tech. We used 1 3/4 in .120 tubing which surpasses the 1 5/8 minimum for this car weight. I'll have weights when I corner weight and align this car. FYI, my 07 Z with a similar cage weighed 3100 lbs low fuel, with a 190 lb driver. I had to add 200 lbs ballast to be legal in SCCA STO racing. These cages are CUSTOM, and can be built to whatever specs and level you desire. Minimum tubing or maximum, 1 3/4 or 1 5/8 tubing, Nascar bars or X bracing for the doors. Also, Rollbars for convertibles who want to do DE's. You name it, we can build it to your specification. BTW, my cage passed tech with flying colors! www.vetttesport.net click on STO 96 for Pics.
Jerry
Old 03-03-2010, 10:49 PM
BERETTA
BERETTA's Avatar
Here you go...
Old 03-04-2010, 08:25 PM
BERETTA
BERETTA's Avatar
Rune
approximately 224lbs added by the cage...
Take in to consideration however the amount of weight that has been removed;
door windows
window regulators and motors
door panels
carpet and padding
radio and speakers
all plastic panels
both air bags
headliner
sun visors
factory seat belts etc.
Old 03-05-2010, 11:35 AM
OCCOMSRAZOR
OCCOMSRAZOR's Avatar
The welding job looks first rate.
However, why did you choose to add so many bars in the rear. I've crashed my car, so I am definately a proponent of good safety equipment, but that rear looks like about 175% of what you actually needed to be safe and legal.
Was there something specific that you were trying to achieve?
Old 03-05-2010, 12:05 PM
SIK02SS
SIK02SS's Avatar
if a certain weight is not a primary concern, more is always better when it comes to safety items like a cage
Old 03-05-2010, 12:38 PM
gkmccready
gkmccready's Avatar
Nope. Unnecessary bars are just unnecessary bars. If they're not going to react a force they're just weight up high and really do not add any safety.
Old 03-05-2010, 01:33 PM
redtopz
redtopz's Avatar
Well you never know what might happen:
To C5ZO6 Roll Cage Completed!
Old 03-05-2010, 01:41 PM
OCCOMSRAZOR
I guess I need to wear two sets of seat belts, then I'll be twice as safe!
Old 03-05-2010, 01:50 PM
sperkins
sperkins's Avatar
Originally Posted by BERETTA
Here you go...
Hmmm....I thought you were supposed to do this:
And you may want to consider integrating the seat mount into the cage:
Old 03-05-2010, 02:26 PM
stairman
stairman's Avatar
[QUOTE=sperkins;1573317515]Hmmm....I thought you were supposed to do this:
That is a much better way, but most people will not go to the effort of removing the tanks.
Quick Reply: C5ZO6 Roll Cage Completed!
