Racepak EFI Vnet module for C6
For the channels it is monitoring, the sample rate seems sufficient. However, it does not provide any feedback on oil pressure which would be nice to have at a higher hz scan rate.
Ask them to try and get it. I emailed the AiM guys and they found it in the data stream and added it for me. BTW, the AiM data systems don't require anything special to interface with the CAN bus on '06+ car. Just connect the two wires and you're done.
Platinum Supporting Vendor
That's odd when I contacted AiM they told me it would not work in a C6 with the E38 VCM. Do tell, is this what you are using and how did you hook it up. I have been thinking about a Racepak but I am also thinking about using the Fast XFI with CAN. I know the Racepak will hook up but I don't think the AiM will work with that one either.
I was told the same thing?
I have asked the RacePak guys a couple of time why oil pressure was not included. They could not really say why.... There is a company called DashDaq that shows all the GM variables, so I think it is there to be mapped if they want. I ordered the C6 module from Racepak and frankly don't use the data it provides as I wish it had oil pressure.
The PITA part is that you have to connect a PC with serial only (pain if you only have USB) to download the config from the G2X once it is installed....
