Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Autocrossing & Roadracing
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results Sponsored by
PFADT Race Engineering
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-01-2010, 04:27 AM   #1
mark b
CF Senior Member
mark b's Avatar
Default Can worn control arm bushings effect tire wear?
I ask this because my driver side front control arm bushing is alittle worn.. the rest are good. I will be replacing it soon and definetly before the track season starts for me.. Im seeing excessive wear on the driver side front tire bottom half towards the outside of the car.
The wear is under the tire.. I know it could be alignment but I dont think that a tire could wear this fast...a few months.. could it be that the weaker control arm is pushing that section of the tire onto the road more thus creating the wear faster?
all you experts please chime in.
I will be replacing the control arm, buying a fresh set of tires and getting an alignment( again) soon.
the tires are nitto r2's not hard street tires maybe with street tires it wouldnt have worn as fast but who knows
mark b is offline   Reply With Quote
Old 02-01-2010, 07:34 AM   #2
Wah
CF Senior Member
Wah's Avatar
Did you check if the control arms bushings were "extruded" ? My C5 Z06 did this and my C6 Z06 is doing the same thing. Curse of awesome brakes and super sticky tires
Wah is offline   Reply With Quote
Old 02-01-2010, 07:39 AM   #3
AU N EGL
CF Senior Member
AU N EGL's Avatar
and alignment challenges
AU N EGL is offline   Reply With Quote
Old 02-01-2010, 10:33 AM   #4
mark b
CF Senior Member
mark b's Avatar
Quote:
the bushing is not "extruded" (does that mean sticking out?) there is just less bushing material there, like its wearing thin. it has happenned only on the top control arm every other one on the car is still good..
yes it is a curse! but a good one
Old 02-01-2010, 11:52 AM   #5
gkmccready
CF Senior Member
gkmccready's Avatar
Send a message via AIM to gkmccready Send a message via MSN to gkmccready Send a message via Yahoo to gkmccready
You're probably not wearing the bushing, it's probably pushing out the other side. Mine were so bad I pulled the upper arms off the car and couldn't get them back on. (I had put studs in the frame.) Note that you can't just replace the bushings with a stock bushing... they don't sell them. So you're either in for a new control arm, or an alternative bushing...
gkmccready is offline   Reply With Quote
Reload this Page Can worn control arm bushings effect tire wear?
Tags
affect, arm, arms, bad, bushing, bushings, car, control, corvette, fast, faster, forum, lower, tire, tires, wear, worn
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
