Aftermarket steering wheels
#221
Does anybody have a plug & play solution for C6 Z06 airbag resistor using the plug at the bottom of the steering column? Attached for photo
I cut all the wiring from the clockspring related to the airbag in order to better fit inside the hub/QR combo.
#222
Just wanted to share an update. I sent the connector from my prior post off to Airbag systems inc along with $30. 4 days later I received back the plug with a resistor that worked flawlessly and now the problem is solved.
el es tu (02-02-2018)
#223
Adapter: Flaming River Spline Adapter (https://www.ebay.com/itm/6-bolt-Stee...-/121826219975)
Quick Release: Lifeline Group N (http://www.lifeline-fire.co.uk/motor...ning-black-224)
Steering Wheel: Sparco R375 (https://www.ebay.com/itm/Sparco-Stee...9WZiLr&vxp=mtr)
work_truck (03-19-2018)
#225
Thanks!
I'm glad you asked because I didn't realize I left out all the information. So I added that above.
Here is what I've got:
I had to trim a hair off of the steering column cover so that the adapter didn't rub, but the way it fits now looks almost OEM.
I also need to order a horn cover, since buttons don't work with the QR
#226
hey guys I ordered an NRG hub SRK-170H and I have a personal neo grinta 330mm steering wheel.
I haven't ordered a quick release yet, it's not necessary right? I do want one but for now to save $$$ getting just the hub. Is that okay?
Secondly what resistor do I need and how do I wire her up? I skimmed through the thread and it seems only C6 info
This is exactly the wheel I got:
Btw, where can I get some of those flat black bolts? I no longer have them. the steering wheel is off my old track car and I don't have the bolts no more lol...
#227
Which version of the NRG quick release is this and will it be compatible with the c5 with the srk-170h hub?
The following 2 users liked this post by KnightDriveTV:
JRitt@essex (07-27-2018),
Moto One (07-02-2018)
#230
