Aftermarket steering wheels
Old 04-18-2014, 09:56 AM
  #181
SinisterC6
SinisterC6's Avatar
Originally Posted by w00tw00t
here is my setup, Sparco R383 Wheel + NRG Short Hub + NRG 2.8 Quick Release
I ended up using the same combo and really like the position of the wheel. The only change over stock Is that when I put the wheel low enough Im blocking the top park of the gauges.
Can you give me more info about your racepak? How do you like it?
Old 04-19-2014, 05:42 PM
  #182
trackboss
trackboss's Avatar
I removed the mechanical lock mechanism on mine. It was several years ago so I don't clearly remember everything, but I machined off all the "spoked" on the ring that engages with the lock. If you don't have a lathe you can simply cut them off. It just won't be as clean, but work just as well.
Old 04-20-2014, 01:09 PM
  #183
GO_BLUE_VETTES
GO_BLUE_VETTES's Avatar
Finished my install yesterday of my new ATI hub and Sparco 325 wheel. If you measure from the the plastic face of the DIC to the outer surface of the week, it is 13.5 inches.
The splines on the ATI hub did not seat all the way down on the splines on the steering shaft. Looking at other peoples photos, I'm thinking I might even have more engagement, based on how far down the nut is screwed. I'll be emailing ATI on Monday just to make sure.
I delayed taking off the column lock completely since I already have a CLB kit installed. Will have 2 lbs of weight to cut out later - especially if I wind up deleting the wipers later!
Old 05-08-2014, 04:35 PM
  #184
MIGHTYM0USE
MIGHTYM0USE's Avatar
has anyone done a quick release stock wheel, (or stock appearing wheel) ?
Old 05-11-2014, 10:18 AM
  #185
SinisterC6
SinisterC6's Avatar
That might be complicated because of the airbag wires but would be cool if executed
Old 05-12-2014, 09:32 PM
  #186
MIGHTYM0USE
im willing to lose the airbag if that helps your answer
Old 05-19-2014, 01:06 PM
  #187
MIGHTYM0USE
anyone else? i like that D shape wheel tho!!
Old 05-20-2014, 06:58 PM
  #188
trackboss
trackboss's Avatar
I have a sparco 375 in perfect condition if anyone is looking for a wheel. $200 shipped
http://subesports.com/products/cat/S...co/prodID/1385
Old 06-11-2014, 12:52 PM
  #189
MIGHTYM0USE
i went with the nrg c6 short hub and their 2.8 quick release in black.
i am going to try to mod the stock wheel into fitting
Old 09-02-2016, 02:46 AM
  #190
1Willy1
1Willy1's Avatar
Keep em coming
Old 09-07-2016, 10:12 AM
  #191
Scooter70
Scooter70's Avatar
NRG hub with their 2.8 Quick Disconnect and Sparco Ring wheel
NRG hub
Sparco Ring steering wheel
Old 09-20-2016, 11:27 AM
  #192
Whis9
Whis9's Avatar
Does anyone know if ATI is still around making products?
Old 09-21-2016, 08:46 PM
  #193
REVHARD
REVHARD's Avatar
They are still around...just purchased and installed mine a few months back with a sparco 375 wheel which is 350mm.
Old 09-28-2016, 08:50 PM
  #194
ZZebes
ZZebes's Avatar
Do you have contact info for them?
Old 09-29-2016, 10:50 AM
  #195
MIGHTYM0USE
I have this for $92 shipped (new) to anyone that may need it. Sold the project.
Old 01-03-2017, 03:00 AM
  #196
Jumpmaster1971
3rd Gear
Jumpmaster1971's Avatar
Default 1975 with Pentias
Old 01-03-2017, 03:06 PM
  #197
sbadd99
sbadd99's Avatar
75 looks good but doesn't appear to have anything to do with the steering wheel thread
The following 2 users liked this post by sbadd99:
rfn026 (01-04-2017), slow_pokeC5 (02-12-2019)
To Aftermarket steering wheels
Old 01-04-2017, 08:03 AM
  #198
el es tu
el es tu's Avatar
does anyone have the wiring or photos of putting the the resistor(s) for the steering wheel airbag? I have not found a kit nor a writeup - just "use a 3 ohm resistor" which is pretty vague... where, which connector slots, how many resistors, what kind of 3 ohm resistors - 5 watt or 10 watt or what?
thanks!
Old 01-04-2017, 03:16 PM
  #199
sbadd99
sbadd99's Avatar
I know they use a 5w, seen that listed many times, didn't work for me so never figured out what to do, tho it did work on a toyota I had ?, so would be interested also, maybe I have another issue as to why it wont cancel out
Old 01-08-2017, 06:09 PM
  #200
alxltd1
alxltd1's Avatar
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
thanks!
First noting all disclaimers regarding the removal of the airbag, you do this on your own.
I used the following link as a guide install my Momo wheel.
https://www.corvetteforum.com/forums...stall-diy.html
I bought the resistor on Ebay several years ago that was designated for a C5, but as the link says you can use One 2 Ohm or Two 1 Ohm resistors to kill airbag light. the connector is behind the knee bolster under the wheel column, the link has pics.
My Momo wheel using a NRG short hub adapter and NRG 2.0 Quick Disconnect.Fully functional horn. The horn ring and button I got on Ebay so I did not have to have the MOMO logo that came with the button on the wheel.
el es tu (01-10-2017)
Quick Reply: Aftermarket steering wheels
