Old 02-20-2015, 05:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
C5 Track Car \ HPDE Conversion: What I have learned!
Old 09-11-2013, 03:27 PM
  #381
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
Battery Section Updated today.
Old 10-05-2013, 09:56 PM
  #382
picklz
picklz's Avatar
Just curious if you still advocate the use of Full TC or Comp mode after the issues you experienced leading to your crash? I see in the 'guide' it's still suggested to use it.
Old 10-24-2013, 02:07 PM
  #383
redhot400
redhot400's Avatar
Great article! Thanks sooooo much for all your time and commitment to us corvette folks. I noticed on your avatar your a corvette addict I'd say I'm right there with you since my lastest C6 Z51 Track car is the eighth Vette I've owned in my 67 years on this planet.
Thanks Again, by the way has anyone done this for a C6 ?
Old 10-25-2013, 11:37 AM
  #384
Zenak
Zenak's Avatar
the 97-01 is the only years with the TC issues. It happens mostly with heavily modified cars more than stock ones. I still suggest that a rookie gets more benefits form the computer nannies then harm, especially if if saves them in a spin out while they are learning the limits of their car in street tires. Same for wet traction, the computer helps.
Once you skill increases, the computer becomes a threat more than a help IMHO. So Skill and conditions based is your answer.
Old 12-18-2013, 04:46 PM
  #385
Elcanadiense
1st Gear
Elcanadiense's Avatar
I've got a 2001 Z06 that I track. Can I upgrade my TC system with a +2002 system and avoid this issues? It may be a pricey endeavor but still cheaper than the a car rebuild after hitting the wall.
BTW, Zenak I can't thank you enought for your thread!!!
Old 12-20-2013, 11:05 AM
  #386
crimlwC6
crimlwC6's Avatar
It would be cheaper and better to do a driving school and learn to run without TC. If you want TC and a vette, it would be better to sell and simply buy a car with the TC system you want if you are concerned. After getting an ABS light over a year ago, I've simply disconnected the ABS computer.
Old 12-20-2013, 11:15 AM
  #387
rustyguns
rustyguns's Avatar
you need to build your driving skills to the point you turn off the TC.
Nice thing about 97-00 cars, is it really does go completely off.
To be sure, I made sure to get a 99 without active handling.
FYI ABS is your friend. you can stop a lot faster and not worry about flat spotting your tires.
All the drivers i know that swear by threshold braking have all flat spotted a tire. Tha'ts $350-450 bucks gone in seconds
If they say otherwise they are lying or just slow
Old 12-20-2013, 11:28 AM
  #388
RX-Ben
RX-Ben's Avatar
What makes you think the '01+ cars don't fully disable TC/AH?
Bad thing about pre-01' ABS is that replacement ABS modules are like $900 (used) and up ($2k new). I just got a spare '01 module for $150 shipped, and they can be repaired for the common relay problem, unlike the earlier ones, for $50. '01+ also has active rear proportioning, which is a plus.
You can probably convert your pre-01 ABS to an '01+ system but I don't know anyone that has done so.
The main tricks to keep ABS happy on the track are to ensure your grounds are good and ensure that your ABS sensor wires are safe (i.e., out of the way of moving parts and wrapped in heat shielding).
Old 12-31-2013, 01:31 PM
  #389
BoostedEBZ06
BoostedEBZ06's Avatar
Originally Posted by rustyguns
you need to build your driving skills to the point you turn off the TC. Nice thing about 97-00 cars, is it really does go completely off. To be sure, I made sure to get a 99 without active handling. FYI ABS is your friend. you can stop a lot faster and not worry about flat spotting your tires. All the drivers i know that swear by threshold braking have all flat spotted a tire. Tha'ts $350-450 bucks gone in seconds If they say otherwise they are lying or just slow
Don't talk to me about flat spotted tires lol I installed Russell SS lines well that quickly rendered my ABS inop due to the impedance problem they have. I ended up locking up my brakes and flat spotting my tires on one of my sessions. -_-
Old 01-03-2014, 03:24 PM
  #390
Zenak
Zenak's Avatar
AS much as I would like to say that "Im too good for ABS" fact is that if you are a weekend warrior racer. HPDE, etc you just dont get enough pedal time to not make a mistake now and again. And if your getting into the ABS once ina blue moon, while it stings your pride... and Mine has been stung by the ABS reminding e I messed up... it saves you $$$ on tire bills. So oh well, my pride is cheaper then tires. ABS isnt a bad thing all the time. Would be great to be driving more, and get a better pedal. But C5 Vette pedals tend to "go away" as the fluid gets hot. And the pressure isnt always consistent on stock C5 brakes to keep a consistent pedal feel.
Old 01-03-2014, 03:26 PM
  #391
rustyguns
rustyguns's Avatar
could not have said it any better. kudos!
Old 02-18-2014, 09:52 AM
  #392
Joshboody
Joshboody's Avatar
Default Bushings
Awesome thread... I'm now in the market for a C5 track toy.
Curious about the poly vs rubber bushings. I haven't seen any info for a mid-level option like a harder rubber. Is it simply 2 choices 1 grade of rubber or poly? Other platforms have various rubber options IIRC.
Old 02-18-2014, 10:13 AM
  #393
LateBreak
LateBreak's Avatar
Poly is basically the harder rubber option, from there you can step up to delrin or solid sphericals for further reduction of deflection in exchange for some added NVH. For what it's worth, I have put solid steel bushings in a street car (G-Body) before and didn't mind them at all, the increased freedom of movement really let the suspension work and I didn't notice anything being more harsh or noisy. YMMV...
Old 02-19-2014, 04:35 PM
  #394
Chris Edwards
Chris Edwards's Avatar
Is this common with Russell lines or just a bleeding issue? I'm about to install Russell lines and i certainly want to make sure the abs works correctly.
Old 02-21-2014, 02:14 PM
  #395
Chris Edwards
Ttt
Old 02-24-2014, 06:42 PM
  #396
Zenak
Zenak's Avatar
Stock break lines are rubber, and NOT recommended for racing application as they fail and when they do its not pretty. Especially the stock lines as the car gets older. if the car wintered etc they get hot cold hot cold hot cold. SS lines of any kind are really recommended. I like the DRM lines kit.
Old 02-24-2014, 06:49 PM
  #397
rustyguns
rustyguns's Avatar
but steel or not, they are only as good as attachment to the connection fittings on each end. That is where it costs $ to build good ones!
All C5's need all rubber replaced, they are old now !!!! bushings, torque tube quidos, belts, hoses engine mounts etc etc
To C5 Track Car \ HPDE Conversion: What I have learned!
Old 05-12-2014, 10:35 AM
  #398
Zenak
Zenak's Avatar
Default almost 100k
Wow, we are almost at 100,000 viewers for this thread! Woo Hoo!
Old 06-28-2014, 08:33 PM
  #399
tytek
Gasoline Addict
tytek's Avatar
Are you back to tracking a car yet? Future plans?
I learned a lot from this thread and very much appreciate your, and everyone else's hard work.
Any prescription that you can suggest to beat the track addiction syndrome?
Old 06-28-2014, 09:24 PM
  #400
rustyguns
rustyguns's Avatar
Only thing remotely close is shooting Heroine ! LOL and you build up a tolerance for it!
Track addiction is always low tolerance Big High !
damn good thread, wish it was around when I started! would have a saved lot of $$$
Quick Reply: C5 Track Car \ HPDE Conversion: What I have learned!
