Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Autocrossing & Roadracing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results Sponsored by
PFADT Race Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-17-2009, 02:57 PM   #1
Anthony @ LGMotorsports
Premium Supporting Vendor
Anthony @ LGMotorsports's Avatar
Send a message via AIM to Anthony @ LGMotorsports
Default **Offical LG GT2 Corvette Rebuild Thread**
Hi guys,
Everyone remembers the scary and horrible fire at Long Beach with Boris behind the wheel of our GT2 Corvette. I am happy to announce that the car is going back together now and will make it's first appearance at the Corvette's of Carlisle show then onto Watkins for it's first shake down runs before Atlanta.
Fire!!
Blasted and Cleaned Frame
Frame being Primed
Frame being painted
Frame complete in red
Front Suspension mounted
Rear suspension going together
Center Switch panel stack
Dash rebuilt and ready for install
Pedals, Steering column, and shifter being installed
Louis and myself are going at it pretty quickly now, so I will be updating the thread with new pictures as the car comes together so STAY TUNED!!!
__________________
Anthony
2006 Z51 M6 coupe. LG Pro Equipped **SOLD**
LG Motorsports
DIRECT DEALERS FOR:
BRAKES: PFC, BREMBO, STOPTECH, GSTOP, WILWOOD
WHEELS: FORGELINE, LG, Fiske, HRE
972-429-1963
anthony@lgmotorsports.com
Anthony @ LGMotorsports is offline   Reply With Quote
Old 07-17-2009, 03:02 PM   #2
rfn026
CF Senior Member
rfn026's Avatar
Wow - that is really apart. is this the first time for the car to be totally apart since it arrived?
Richard Newton
rfn026 is offline   Reply With Quote
Old 07-17-2009, 03:12 PM   #3
Kubs
CF Senior Member
St. Jude Donor '09-'10-'11
Support Corvetteforum!
Kubs's Avatar
kubs363 Kubs63
Wow! Looks great! Good luck with the rest.
Kubs is offline   Reply With Quote
Old 07-17-2009, 03:44 PM   #4
RedLS1GTO
CF Senior Member
RedLS1GTO's Avatar
Location: Louisville, KY - Cincinnati, OH .................... Color my life with the chaos of trouble.
This is going to be an awesome thread...
RedLS1GTO is offline   Reply With Quote
Old 07-17-2009, 03:51 PM   #5
bowmanized
CF Senior Member
bowmanized's Avatar
Wow, that's so sick Lou. The tank must be the dry sump.
What's the total weight(wet) without driver?
Glad to see you getting it back together.
Go get 'em.
Mike
bowmanized is offline   Reply With Quote
Old 07-17-2009, 03:58 PM   #6
Quote:
Richard Newton
Louis stripped it down at Riley right after Sebring 2008, this is the first time since then that it has been this far apart.
Old 07-17-2009, 04:05 PM   #7
Louis @ LG Motorsports
Louis @ LG Motorsports's Avatar
Quote:
We stripped it down to basically suspension and wiring after Sebring in '08, then flipped it to correct the floor flatness, but did not have time to completely strip it and paint it like this. We are allowed 5mm deviation from a pure flat bottom
Louis @ LG Motorsports is offline   Reply With Quote
Old 07-17-2009, 04:07 PM   #8
wmckeenster
CF Senior Member
GREAT thread!
wmckeenster is offline   Reply With Quote
Old 07-17-2009, 04:38 PM   #9
Lancer033
CF Senior Member
Lancer033's Avatar
Send a message via Yahoo to Lancer033
Lancer033 is offline   Reply With Quote
Old 07-17-2009, 06:06 PM   #10
HORNDAWG
CF Senior Member
HORNDAWG's Avatar
Cool, good to see the car coming back together. Now for some sponsorship!
How much longer does the chassis have on its homologation? And can Riley re-homologate/update the car/chassis/design and extend its homologation life (ACO) as long as it is in production?
L.P.
HORNDAWG is offline   Reply With Quote
Old 07-17-2009, 06:40 PM   #11
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
We're going to miss you at Lime Rock this weekend!
I like your bushing solution
__________________
Polo Green 95 LT1 6-spd
383 LT1/Vortech Supercharger/AFR heads/Rod end suspension/Penske-Hardbar dual rate coilovers/Wilwood 6pot brakes
NCCC Governor/Membership/WebMaster: www.baystatecorvetteclub.com
BrianCunningham is offline   Reply With Quote
Old 07-17-2009, 07:46 PM   #12
LG Motorsports
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Go get 'em.
Mike
Hi,
Yes, that is the dry sump tank. The car has to weigh 1220 kg with no fuel and no driver. that is 2684 lbs. This will be the absolute first time it will be exactly down to min weight. We were close before but this time we should need a little balast.
Lou g
Old 07-17-2009, 07:47 PM   #13
StealthLT4
CF Senior Member
StealthLT4's Avatar
Send a message via AIM to StealthLT4
Aw man! I was really looking forward to seeing the Corvette at Lime Rock this weekend. Good luck with the rebuild!
StealthLT4 is offline   Reply With Quote
Old 07-17-2009, 07:52 PM   #14
davidfarmer
CF Senior Member
davidfarmer's Avatar
never mind
davidfarmer is offline   Reply With Quote
Old 07-17-2009, 09:03 PM   #15
LG Motorsports
We will keep you all updated as the car goes back together. It will be at Corvettes of Carlisle in 5 weeks. Stop by if you can make it.
The homologation is all ACO is still being worked on. GM originally granted the GT2 Homologation to Riley then they changed their mind when they were forced due to not enough bail out money to run GT2.
So Gm pulled their promise on the FIA homologation but that is supposed to change now that they are pulling out of most racing around the world. So Riley is working on the FIA part as we speak.
LG
Old 07-17-2009, 09:26 PM   #16
JEPopp
Junior Member
JEPopp's Avatar
GREAT THREAD & PICS !
Too bad it won't be together in time to run up at Road America. With the power you have, I would think the long straights might play to your strength. (But I may be completely wrong, I'm just a fan of road racing with a Corvette in the garage)
JEPopp is offline   Reply With Quote
Old 07-18-2009, 12:01 AM   #17
longdaddy
CF Senior Member
longdaddy's Avatar
what's "brake blower"?
longdaddy is offline   Reply With Quote
Old 07-18-2009, 02:09 AM   #18
LG Motorsports
Brake Blowers are in line 3" fans that blow air through the brake ducts for use mainly on Yellow flags and during a pit stop if necessary.
LG
Old 07-18-2009, 08:18 AM   #19
jrmotorsports55
CF Senior Member
Glad to see it's coming together.
Good luck!
Jason
jrmotorsports55 is offline   Reply With Quote
Old 07-18-2009, 09:43 AM   #20
Everett Ogilvie
CF Senior Member
Everett Ogilvie's Avatar
Glad it is going back together - great build thread!
Everett Ogilvie is online now   Reply With Quote
Reload this Page **Offical LG GT2 Corvette Rebuild Thread**
Tags
c6r, corvette, corvetterollcagefootprotection, frame, gt2, intake, kinsler
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
