A Arm bushings pushed out a note to all
Old 07-13-2009, 05:59 PM
dvandentop
dvandentop's Avatar
Default A Arm bushings pushed out a note to all
dont unbolt your upper a arm if the bushing is popped out to the side a little bit, it sure makes for fun to get the bolts all lined back up again
So dont unbolt the upper a arms unless ready to replace the bushings
Old 07-13-2009, 07:26 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
Old 07-13-2009, 07:27 PM
dvandentop
dvandentop's Avatar
Originally Posted by ajg1915
Old 07-13-2009, 07:55 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
^ Wow, they really did take a beating, what are you going to use to replace ?
I went with VBP bushings and I'm going to install zert fittings.
Old 07-13-2009, 07:58 PM
dvandentop
dvandentop's Avatar
got my vbp today via UPS and they forgot the lube in the package
yeah once i get them off i will look at grease zerks also would make it alot easier if sqeeks do show up
Old 07-13-2009, 08:14 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
I just used some high temp brake grease in those little green packages that you buy at the local auto store.
Works great.
I've got the car up on the lift as we speak in pieces. Putting in a 416 forged motor and converting over to a RPM A4 tranny with C6 Z06 differential set-up.
Got a bunch of suspension upgrades and re-wiring to do too. I converted my coupe to hardtop with a widebody kit from ACP.
Got a ways to go before finishing project.
Before
After
Old 07-13-2009, 09:06 PM
dvandentop
dvandentop's Avatar
any tips for the bushing install at all??
also what size zerx fittings did you use on the a arms?
did u cut some grooves into them also?
Old 07-13-2009, 09:40 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
I pulled the "A" arms off the car. The top front bushings come out using a vice some WD-40 or the like and twist them off.
I used a ball joint press and some lubricant to press out the other bushings.
I greased everything up and used a vice to press them in.
I haven't done the Zert fittings yet. Some guys have cut groves in the bushings but I see no need to that with the zert fittings.
Tony
Old 07-13-2009, 10:13 PM
kmagvette
kmagvette's Avatar
On the uppers I the mounts on the skinny side of the bushing and then pressed the bushings out with a bearing press I borrowed from Advance Auto parts.
For the others, I cut one end of the bushing flush with the control arm and down to the metal sleeve. Then used the bearing press to push the bushings through.
The first one sucked, then it gets easier.
Wish I thought about zerk fittings...oops.
Old 07-13-2009, 10:14 PM
dvandentop
dvandentop's Avatar
so it is possible to get it all done with the loaner tool from advanced auto and not use a actual big machine press?
if so that makes things alot easier
Old 07-14-2009, 02:30 AM
gkmccready
gkmccready's Avatar
Even more fun if you have a stud kit. That is *exactly* what made me suck it up and put poly in all the control arms...
Old 07-14-2009, 07:31 AM
kmagvette
kmagvette's Avatar
Yep. I forgot to mention lubing the bushing as you cut them...this is more important if you use a hand powered hack saw. WD-40 or your favorite 3-in-1/Marvel oil works. I quickly gravitated to my precision sawsall with a metal blade- much faster, but you need to stay awake while cutting.
I did a camber kit at the same time which included a stud kit (Hardbar), I had no issues at all with that part of the install other than the car handled like a shopping cart with a spinning front wheel until I got it aligned. It was so bad I thought I must have screwed something up. This is also a great time to go to hardened studs since you will be in there anyway...these too are a no brainer. Watch the DRM video, it really is that easy.
Don't know if it matters, my car is a C5 Z.
Old 07-14-2009, 08:12 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Save yourself a lot of time and forget about cutting anything. Just lube up the bushing and push it out with the ball joint press.
It takes about 5 minutes each, mainly to set it up each time.
Old 07-14-2009, 09:35 AM
dvandentop
dvandentop's Avatar
so upper and lowers can be done with ball joint press? thanks alot
also i am guessing ball joint press to install the new ones also
Old 07-14-2009, 10:23 AM
dvandentop
dvandentop's Avatar
ok so just got a message from vbp since the lube wasnt included supposedly the bushings self lube themselves is what they said.
If i want to i can put some on myself. I dont think i feel comfortable installing them without any grease. anyone else had these claims before about vbp not needing any grease??
Old 07-14-2009, 12:10 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Don't know if they changed but mine came with grease. Just pick up some high temp green lube that thet use on brakes at the local auto shop.
You'll need a vice to install the new bushings, they are split in half and push in from each side. The biggest PIA is getting the washers on and off the bottom control arms.
Old 07-14-2009, 04:42 PM
dvandentop
dvandentop's Avatar
got some good grease at oreilys that hopefully will be ok
Old 07-14-2009, 05:42 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
go to NAPA and get some die-electric grease their tube is big and cheap.
Old 07-14-2009, 05:46 PM
dvandentop
dvandentop's Avatar
got a 1lb can of grease for like $4 from oreilys it has some stuff in it for high pressure joints etc... and said bushings on it so should be good
To A Arm bushings pushed out a note to all
Quick Reply: A Arm bushings pushed out a note to all
