Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Autocrossing & Roadracing
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results Sponsored by
PFADT Race Engineering
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-26-2009, 04:50 PM   #1
95jersey
CF Senior Member
95jersey's Avatar
Default Those with Stoptechs, step inside please...
How long do your track pads last (track events)? Trying to guage how long they last compared to same compound but using OEM calipers.
95jersey is offline   Reply With Quote
Old 06-26-2009, 04:55 PM   #2
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
Quote:
It would probably help if your profile listed your car to determine which OEM pads you have.
San
oldmansan is offline   Reply With Quote
Old 06-26-2009, 05:24 PM   #3
95jersey
CF Senior Member
95jersey's Avatar
C6z06
Old 06-26-2009, 06:58 PM   #4
MySR71
CF Senior Member
MySR71's Avatar
This is rather subjective due to tracks and driving style but here is some info for my setup.
Power wise my car it is stock. I run street tires (Falken RT-615's) and have the StopTech ST60 fronts and ST40 rears. Both front and rear have 14" rotors. I went to StopTech's due to spreading the stock calipers which gave a low pedal which would not pump up and also gave a lot of pad taper. On track, I use CarboTech XP10's on the front and XP8's on the rear. The front pads are just about shot after 9 days of tracking. That includes 6 days at Grattan Raceway and 3 days at Gingerman Raceway. I haven't pulled the pads after this last event but previous to that, there was minimal taper.
Now, I say that the front pads are just about shot but there definately still meat on them. If you're inclined to run them all the way to the backing plates, they could probably do another couple of days.
I do have DRM front cooling ducts and LGM spindle ducts. The front rotors do have heat checks after the 9 days of tracking but are definately still good.
Overall, I have been very happy with the StopTech setup and the CarboTech pads. No fade issues. I do run Motul brake fluid and bleed before every event.
I hope the above helps in some way.
MySR71 is offline   Reply With Quote
Old 06-30-2009, 06:06 PM   #5
carbotech adam
Premium Supporting Vendor
St. Jude Donor '11
carbotech adam's Avatar
carbotech adam is online now   Reply With Quote
Old 07-01-2009, 02:16 AM   #6
ccj
CF Senior Member
ccj's Avatar
C5Z, St60/ST40, 14" rotors. Front Cobalt XR2 pads have 7 events on them and look to be good for another 1 or 2.
ccj is offline   Reply With Quote
Old 07-01-2009, 10:46 AM   #7
DOUG @ ECS
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
Matt, the Stop Tech's are great, I have about 10 track days on my pads and can probably get another day, maybe two. Since we generally run the same tracks with about the same weight, it should be comparable. The additional expense on purchase gets weighed out over time, and the stopping power is incredible.
Go with them, even if your playing with higher HP cars on the track, I can almost always make the distance lost on the brakes.
DOUG @ ECS is online now   Reply With Quote
Old 07-01-2009, 10:49 AM   #8
95jersey
CF Senior Member
95jersey's Avatar
Thanks for the input guys. Whether I run the paddlets or the single pad, I am now getting about 4 events (single days) out of the fronts. That is trying to be somewhat conservative on my braking points to make them last longer. At $300 per set, I am spending more than double on what you would spend with Stoptechs's (ST60 pads are approx $200). So in just 8 events, I would save around $400. In 2 years, they have paid for themselves...man I just have to pull the darn trigger.
Old 07-01-2009, 11:53 AM   #9
Z06Fix
CF Senior Member
Z06Fix's Avatar
Send a message via AIM to Z06Fix
Do you find any advantage of the single piece pad over the paddlets?
__________________
Eric Lewis
2008 JSB Z06
Z06Fix is offline   Reply With Quote
Old 07-01-2009, 11:58 AM   #10
95jersey
CF Senior Member
95jersey's Avatar
I think the single pad lasts a little longer in general, I have little to no pad taper, but I could not tell a big difference in performance if any.
The advantage for me is ease of installation. The single pad cuts down the install time significantly as you are not bumbling with 6 little paddlets falling all over the place. I will never buy a paddlet again!!!
Old 07-01-2009, 12:07 PM   #11
GrantB
CF Senior Member
What ST-60 pads are $200? I believe Cobalt XR1s are around $400?
GrantB is offline   Reply With Quote
Old 07-01-2009, 12:11 PM   #12
95jersey
CF Senior Member
95jersey's Avatar
Quote:
Carbotechs
Old 07-01-2009, 12:16 PM   #13
Z06Fix
CF Senior Member
Z06Fix's Avatar
Good info. Thank you
__________________
Eric Lewis
2008 JSB Z06
Old 07-01-2009, 12:26 PM   #14
carbotech adam
St. Jude Donor '11
carbotech
CTST60-XP10 $234
Old 07-01-2009, 01:40 PM   #15
DOUG @ ECS
DOUG @ ECS's Avatar
Quote:
Originally Posted by carbotech adam View Post
carbotech
CTST60-XP10 $234
Good to know.
Old 07-01-2009, 02:19 PM   #16
Anthony @ LGMotorsports
Anthony @ LGMotorsports's Avatar
Send a message via AIM to Anthony @ LGMotorsports
The other thing you have to think about is that the factory caliper will only allow for a 15mm thick pad. Going to the one piece design does give you a little more surface area but it does not increase thickness.
StopTech's ST60 caliper allows for a 20mm thick pad, so you are gaining 5mm of pad material on each side which is a good size increase of about 30% total.
Comparatively speaking with Cobalt pads and the same compound the StopTech pads are cheaper than OE.
Matt, I'll get you a set boxed up and ready to go, just hit me up when your ready!
__________________
Anthony
2006 Z51 M6 coupe. LG Pro Equipped **SOLD**
LG Motorsports
DIRECT DEALERS FOR:
BRAKES: PFC, BREMBO, STOPTECH, GSTOP, WILWOOD
WHEELS: FORGELINE, LG, Fiske, HRE
972-429-1963
anthony@lgmotorsports.com
Anthony @ LGMotorsports is offline   Reply With Quote
Old 07-01-2009, 03:15 PM   #17
vms4evr
CF Senior Member
vms4evr's Avatar
In 2 years they pay for themselves? I must be missing something here. What pays for itself? That ST60/ST40 kit (calipers,brackets,rotors) cost you what $5k? You'll need to use an awful lot of pads to ever break even on costs. Also with a BBK like that don't you need a new master cylinder?
vms4evr is offline   Reply With Quote
Old 07-01-2009, 03:30 PM   #18
Quote:
Not with StopTech you don't. These were all designed around the factory ABS and master cylinder calibrations.
__________________
Anthony
LG Motorsports
DIRECT DEALERS FOR:
972-429-1963
Old 07-01-2009, 03:31 PM   #19
oldmansan
CF Senior Member
St. Jude Donor '09
oldmansan's Avatar
I picked up a ST40/ST40 kit for $3300 shipped from a forum vendor. New. Stoptech told me the only advantage to the ST60 caliper was a bit longer pad life. They said there wouldn't be any performance difference and that if I drove two cars back to back I wouldn't know the difference. The ST40 pads are quite a bit cheaper than the ST60 pads. You don't need a new master cylinder to run a properly designed BBK.
San
Old 07-01-2009, 04:02 PM   #20
95jersey
CF Senior Member
95jersey's Avatar
I am talking fronts only. If the pads last twice as long and cost $100 less than the Stoptechs, and you do about 8-10 events a year. You will pay for the updgrade in the form of savings on the pads. Now I just need to sell some more parts I have laying around the garage to help me pay for these things.
Reload this Page Those with Stoptechs, step inside please...
Tags
cobalt, pads, st60, stoptech, xp10, xr2
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
