Wider tires vs coil overs
Re: Wider tires vs coil overs (MAC95 6SPD)
What are you running now? What size rims do you have?
Tires are first
[Modified by John Shiels, 8:12 PM 2/4/2002]
Tires are first
Re: Wider tires vs coil overs (John Shiels)
i'm running stock wheels with 275/40/17 BFG g force KD's. I'm thinking of putting 17"x11" wheels with 36mm offset on the rear with 315/40/17 g force tires and leaving the front as is.
Steve
Steve
Re: Wider tires vs coil overs (dantos)
That should work. But as stated above track time is the best. The tires in stock size should be good too. There may be other things to do first as coilovers are a bunch of money. Set of tires and rims are costly too. Look for bang for the buck.
[Modified by John Shiels, 12:07 AM 2/5/2002]
