[PICS] Katech's Mosler MT900KR project
Old 04-13-2009, 04:45 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default [PICS] Katech's Mosler MT900KR project
I thought you guys might like to see the progress of our Mosler MT900KR project. We basically took the MT900S street car and converted it into a track-day/HPDE machine.
Custom built LS2-based 427
Carrillo H-beam rods
Callies Magnum crankshaft
Katech pistons, just over 11:1 CR
DLC pins
GM Stage 3 cam
LS7 heads
Carbon fiber valve covers and coil relocation kit
Expected to make about 640hp.
Considering the car's light weight, awesome power, and phenomenal cornering ability, a proper dry sump system was high on our priority list. This features a custom made dry sump system with ARE pan and Dailey 3 stage scavenge pump. Internal pressure pump. The dry sump system was custom designed to fit within the space constraints of the Mosler and still retain the AC for those hot track days (the Mosler has almost no side window). Also a custom made alternator bracket to make space for the dry sump pump.
I'll post more pictures as things progress.
__________________
Contact:
(e) zach@katechengines.com
Old 04-13-2009, 04:53 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
That's going to be a beast!
Old 04-13-2009, 05:07 PM
mcar00
mcar00's Avatar
Beautiful. This has always been, in my opinion, the ultimate street/track car. Relatively easy to work on, lots of Corvette parts, lightweight and proven. Cost and the ability to find one being the only disadvantages. I remember being at the Moroso road course several years ago and having one of these fly by my C5 Z06. I had to check to make sure my car was actually in gear. Unfortunately it was.
Jason, how does the LS2 based 427 compare with the LS7 Street Attack? Advantages and disadvantages, cost, etc.
This will surely be a monster!
Old 04-13-2009, 05:45 PM
Gary04Z06
Gary04Z06's Avatar
Old 04-13-2009, 06:04 PM
Katech_Zach
There are a lot of similarities with the Street Attack LS7 especially since this particular one has LS7 heads. Costs used to end up the same until recently when the price of the LS7 base engine went up. Now it is more cost effective to do a Value 427 LS2 with LS7 heads (if you don't have an LS7 already).
Old 04-13-2009, 07:01 PM
The Clevite Kid
Support Corvetteforum!
The Clevite Kid's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
A wide-band air/fuel ratio sensor for each cylinder !! No excuses on the tune for this bad boy.
Old 04-13-2009, 07:20 PM
Katech_Zach
Yes, those are the dyno headers with 8 EGT and 8 O2 channels. That is the way to do it properly on the engine dyno. The car won't have that.
Old 04-13-2009, 07:36 PM
Short-Throw
Short-Throw's Avatar
Yup, and it will be at Track Attack in 25 days.....this time with a serious attitude!
Everett was kind enough to let me drive the car last year. I think I may have to drive it again, just to make sure everything is working properly.
Mike
Old 04-13-2009, 07:49 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Mike
NOW I am getting excited Mike - as the project starts to come together the reality is sinking in! I suspect the car will be able to scare the you-know-what out of me and I will definitely need to have a new level of respect for the power!
Maybe you and I will have to trade off a Beast drive for a MT900KR drive!
Old 04-13-2009, 08:00 PM
TLGunman
TLGunman's Avatar
Schweet!!
Originally Posted by Katech_Jason
I(the Mosler has almost no side window).
Specifically, the MT900's using the side window design done in the UK...the last thing I did, before leaving Mosler, was brief them on my window design, that would allow the full side glass to go down. This was the first production car, with the full window: Click me, to see
Old 04-13-2009, 09:41 PM
LS3FORME
LS3FORME's Avatar
unreal cars, there are one or two here in boca raton one is WM's partner in one of the companies, we see it around alot, leave your lambo at home, this is a real car. I have been flowing his products down her since the early dodge powered consuliers. They def got it right with this bad boy.
Good job K tech good job Warren.
Old 04-13-2009, 10:42 PM
Short-Throw
Let's start you off with the Volvo!
Everett,
Aside from seeing the car perform, I can't wait to hear how it sounds!
Old 04-14-2009, 11:38 AM
Everett Ogilvie
I was hoping to at least start with the CTS-V...
I am happy that Jason and Katech figured out how to properly dry sump the system - no small job because space is at such a premium. It looks like a great job!
Old 04-14-2009, 12:03 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
I can only imagine how quick that is going to be. In the 40 something at Lime Rock if you ran it there. Trans Am cars do 51's there the record is 43 something.
Old 04-14-2009, 02:10 PM
YELLOHHH
YELLOHHH's Avatar
What, no Air Attack 1000+ rwhp motor?
Old 04-14-2009, 05:13 PM
Katech_Zach
Old 04-14-2009, 05:51 PM
Everett Ogilvie
650 HP/564 lb ft...
Remember that thing I said about respecting the new level of power.....
WOW!
To [PICS] Katech's Mosler MT900KR project
Old 04-14-2009, 07:30 PM
dvandentop
dvandentop's Avatar
gonna have to hang on everett it is going to be a rocket ship!!!
Old 04-14-2009, 07:35 PM
ghoffman
ghoffman's Avatar
OMG, ya think? Hey, please don't be proof testing the harnesses ok?
Old 04-14-2009, 07:51 PM
kentz06
kentz06's Avatar
I have seen this car from EVERY angle () and there are few places for aerodynamic drag. It is so flat and clean on the bottom it must develop considerable ground effect down force.
With the light weight, new Katech power and more limber suspension, no one is going to be safe!
I am sure looking forward to seeing her again!
Congrats Everett!!!
Dean
Quick Reply: [PICS] Katech's Mosler MT900KR project
