C6 Z06 Autocross Setup
Old 01-16-2009, 06:47 PM
ratt_finkel
ratt_finkel's Avatar
Default C6 Z06 Autocross Setup
We'll be running an 08 C6Z this year. Having some difficulty nailing down the best tire size.
Co-driver and I will probably be trying many different setups this year.
My first stab will be Hoosier A6's with 315/30/18's up front. And 345/30/19 in the back.
I'm anxious to try the 325/30/19 in the back for gearing purposes. But want to see how well the car will put down power with the big meats.
May try 295's in the front, but I feel like that's too small of a size for the front. We'll see.
Alignment: We'll be shooting for 2ish negative in the front and 1.5 negative in the rear. 1/8inch toe in for the rear. Zero toe in the front.
Have a lightweight exhaust being built as we speak.
I'm still undecided on front bar, shocks. And I'm curious if anyone knows of any stock legal rims besides OEM and the TireRack selections.
So far, the car has proven to be a blast on the street. Can't wait for the first Auto-X!
Jeremy Foley
Old 01-16-2009, 07:14 PM
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
Assuming you are running in SS, I can't say that you are going to fit 315's on the front 9.5" rim.
If I am not mistaken the C6Z06 comes with:
18 x 9.5" fronts
19 x 12" rears
Most I know w/ the C6Z06 run Hoosier A6's. I assume Kumho has those sizes out now, but I know they didn't for a while. 295/30-18 fronts / 345/30-19 rears
Old 01-16-2009, 07:33 PM
TedDBere
TedDBere's Avatar
Jeremy, just sell it and go back to a C5Z to save yourself the aggrevation.
JK...good luck.
Old 01-16-2009, 09:09 PM
sammm
sammm's Avatar
Another new Z06 owner...Congrats J-Fo!
http://forums.corvetteforum.com/auto...ssing-z06.html
Old 01-16-2009, 09:11 PM
Racin Time
Racin Time's Avatar
The 315's will fit the front just fine.
Old 01-16-2009, 09:31 PM
ratt_finkel
18 x 9.5" fronts
19 x 12" rears
Yes, this car will be run in SS.
Sadly, Kumho does not have any 19" v710's. So hoosiers it is.
Old 01-16-2009, 09:37 PM
TedDBere
TedDBere's Avatar
Kumho's not paying contingency monies this year anyway.
Old 01-16-2009, 09:51 PM
Racin Time
Racin Time's Avatar
The Tirerack ad in Sportscar listed the Kumho V710 in a 335/30/19 but it's not on Tirerack's web site. Don't know why it's not on their web site.
Old 01-16-2009, 10:34 PM
OzCop
OzCop's Avatar
Hey Jeremy, congrats on the SS C6 Z ride! You're going to love it...
...wish I had a z...wish I still lived in TX! It's cooold here...
Phil O.
Old 01-17-2009, 03:24 AM
ratt_finkel
Phil O.
Hey Phil! Miss ya man! Hope you're doing well! I looooooooooooooooooooooooooooooooooooooo oove the car so far.
Wish it was racing time!
Old 01-17-2009, 08:18 AM
Datawiz
Support Corvetteforum!
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
I run Hoosier A6's 295 in the front and 345 in the rear. I have Pfadt Racing Inverted sport shocks and have just ordered their adjustable SS Sway bar. I run -2.4 Camber in the front, -0.7 in the rear along with some toe out in the front and about 1/4" toe in at the rear.
I'm getting pretty close to the top of the heap where I run. We'll see if that translates into success at Dixie in March .
Oh yeah, mine's an '08 as well.
Old 01-17-2009, 08:33 AM
Racin Time
Racin Time's Avatar
Datawiz:
Several guys in my region complained about the C6Z wanting to push. Did you experiance a problem with the car wanting to push?
Old 01-17-2009, 08:34 AM
gonzalezfj
gonzalezfj's Avatar
You are running close to the ideal setup. I ran -1.4 degrees of negative camber in the rear for a little more grip coming out of corners. I also had Penske shocks, but the Pfadts will do just fine.
Frank Gonzalez
Old 01-17-2009, 10:42 AM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
Originally Posted by Racin Time
Datawiz:
On a stock alignment with street tires it pushed some.
I don't push at all now. I've got the Pfadt shocks set pretty soft in the front to help it turn. I'm on setting 5 of 16. I run 12 in the rear. In the event we just finished, the car felt fantastic.
Old 01-17-2009, 10:44 AM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
Frank Gonzalez
I've run with -1.5 in the back before and I really didn't like it. The car felt twitchy and straight-line acceleration suffered.
Old 01-17-2009, 02:18 PM
ratt_finkel
What do you mean by twitchy? And what elements did the car feel twitchy in?
I'll keep a tab on your progress at Dixie! Good luck to you!
Old 01-17-2009, 04:06 PM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
The car just doesn't feel planted and the back end feels like it wants to dance all over the place, even in a straight line. It was very unnerving for me.
If you think about it, it kind of makes sense. The more negative camber you put in, the smaller the contact patch when going straight. I understand why we want to go negative, so we maximize the contact patch in the turns. For me, I'm just balancing the positive and negative benefits of both, along with making me comfortable behind the wheel.
To C6 Z06 Autocross Setup
Old 01-17-2009, 07:06 PM
ratt_finkel
Has anyone else driven your car reported the same thing?
Please don't take any offense to this. But have you had any success on the national level?
I'm open to any advice on alignment. We're only going to have 3 events to dial in the car before the Houston Tour. So it would be nice to start off with something close to right.
Old 01-17-2009, 07:12 PM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
I am co driving with Joan Clark this season. She and Steve Burger are pretty well known in this sport. Both drove my car quite a bit last season, but not with the -1.5 in the back.
I have NOT run nationally yet, but will be doing Dixie and Lincoln at a minimum this year. I finished my past event 4th in PAX and was only 0.05 seconds behind 2nd. Darrin Disimo and Dave Lehman were 2 of the 3 in front of me. Disimo finished 4th at Topeka in CS. Lehman finished 7th in ASP. His co-driver, Hector, finished 4th.
Lehman has been egging me on to run nationally. It's time. I'm certain I won't win. Christ, I'm 6'5", 290 pounds. I'm my own handicap.
I think Joan will win SS Ladies in Dixie.
I'm VERY close to the top. The sway bar and some more minor adjustments and I think I get FTD with this group.
Old 01-17-2009, 07:28 PM
ratt_finkel
Yes, I know Darrin very well. Have run into Lehamn a few times. Know of hector. Tough group to run with.
I wish you luck on the national scale. It's a whole different ball game. Hopefully we'll meet up sometime.
Tell Disimo I said hi.
Quick Reply: C6 Z06 Autocross Setup
