Hawk HPS vs. OEM Brakes
Old 03-18-2008, 10:15 PM
USA1C5
Support Corvetteforum!
USA1C5's Avatar
Default Hawk HPS vs. OEM Brakes
My question is: How much better are Hawk HPS brake pads over the OEM brake pads. I realize that Hawk HP Plus brake pads will give better stopping power over either Hawk HPS or OEM brake pads or at least they should. But I'm curious about the Hawk HPS vs. OEM pads. I found the OEM brake pads did very well at HPDE's for me so will the Hawk HPS pads be an improvement or would they be much the same? This is on a C6 Z06 which I think have very good OEM brakes to start with.
Old 03-18-2008, 11:58 PM
RidgecrestC5
RidgecrestC5's Avatar
I'd be interested in hearing about this also from a C5 perspective. TTT
Old 03-19-2008, 04:51 AM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
HPS are worse than stock C5 Z06 pads. HP+ are a little better.
Old 03-19-2008, 07:30 AM
AU N EGL
AU N EGL's Avatar
I Like the stock C5Z pads better then both the HPS and HP+ both of the HP pads had far more brake dust then the stock C5Z
Old 03-19-2008, 08:56 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I would go with the C5Z pads over the HPS pads.
Old 03-19-2008, 10:16 AM
USA1C5
USA1C5's Avatar
I find that the OEM pads are very, very dusty on the C6Z. The Hawk HPS advertize low dust. Can anyone with C6 Z06 verify this? It sounds like OEM pads on C5Z is better than Hawk HPS, how about C6Z?
Old 03-19-2008, 01:34 PM
BQuicksilver
Agreed. If you factor dusting in the OEM pads may be superior to both. IMO the HP+ do have a bit more stopping power.
Old 03-19-2008, 03:32 PM
jbauch357
jbauch357's Avatar
HPS feel dangerous they have so little grip compared to stock Z06 pads, but they don't dust.
Stock Z06 pads feel good, and dust - but not excessively. These are what I have chosen to run on the street...
HP+ feel fantastic, but dust like mad.
Old 03-19-2008, 03:38 PM
Lancer033
Lancer033's Avatar
HPSs were the first aftermarket pad I tried and they didn't stop that much better the the OEM pad and made a whole lot more noise and dust.
Old 03-19-2008, 03:41 PM
USA1C5
USA1C5's Avatar
This is the kind of information I'm trying to find out about the C6 Z06. So far no info on the C6 Z06. Your info probably holds true for the C6 Z06 but not confirmed by anyone yet.
Old 03-19-2008, 08:07 PM
jbauch357
jbauch357's Avatar
sorry, missed that part of the original post - those were my experiences with a C5Z...
Old 03-19-2008, 08:20 PM
USA1C5
USA1C5's Avatar
Thanks anyway. Still looks like no one with a C6Z has tried the Hawk HPS pads, I guess I'll have to be the Guinea Pig.
To Hawk HPS vs. OEM Brakes
Quick Reply: Hawk HPS vs. OEM Brakes
