Wallyman's mobile frame shoppe... (lots of pics)
Old 03-01-2007, 01:48 PM
wallyman424
wallyman424's Avatar
Default Wallyman's mobile frame shoppe... (lots of pics)
Well, less than a week from getting punted off track at VIR, I'm glad to say that I've fixed my bumper beam! The SMC tub that was all mushed in just popped back into place. All i have left to do is epoxy the outside of it for strength, and make some brackets out of aluminum for the body panels.
I want to give a BIG thanks to David Farmer for taking the time to respond to probably 10 or so PM's.
The torch.
My advanced fire fighting apparatus. Only the water was used.
The damage.
The anchor (lincoln navigator) and the 20 dollar harbor freight come-along
Tow strap to spread the force. (all the water on the floor is from where i lit the tub on fire, yelled OH ****, and doused it with bottled water. then i took a swig for good measure.)
SUCCESS!!!!
No more rubbing!!!!!!!
After this experience, I'll definitely be taking my MAPP torch and come along to the track.
Old 03-01-2007, 02:00 PM
Falcon
Falcon's Avatar
Wallyman, You are da Man!
Isn't it nice having a racecar. Just pull, prod and push until it's fixed and back on the road again.
Old 03-01-2007, 02:08 PM
Akcelr8 N VA
Akcelr8 N VA's Avatar
Way to go!! I'm glad you were able to fix it with a minimum of cost. Congrats on the Comp License... I'm gonna miss seeing you blow by us in HPDE. See you at VIR in March.
Old 03-01-2007, 04:29 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Woooohooooo, another satisfied customer!
Old 03-01-2007, 05:18 PM
AU N EGL
AU N EGL's Avatar
hot dang Wally. But your suppost to swig the burboun. hick
To Wallyman's mobile frame shoppe... (lots of pics)
Quick Reply: Wallyman's mobile frame shoppe... (lots of pics)
