Aftermarket seats on stock rails?
Old 10-27-2006, 09:33 AM
...Mark...
...Mark...'s Avatar
Default Aftermarket seats on stock rails?
Is this even feasible?
If so which seats?
I'm thinking its not worth the headache.
Old 10-27-2006, 09:54 AM
woosch
woosch's Avatar
There are a few seats that use the stock rails. What are you looking for? Just an upgraded seat, check out Caravagio (SP), there are quite a few race seat options some with stock rails some with aftermarket.
Old 10-27-2006, 10:28 AM
...Mark...
...Mark...'s Avatar
Looking at the Corbeau A4's or a similar style reclining sport seat. I want to keep the cost down (under $1k) so the Caravagio's are not an option. I'm just looking for a little more lateral support.
Old 10-27-2006, 10:35 AM
woosch
woosch's Avatar
The biggest issue is finding seats that will fit in the car, width wise... I do know Corbeau does make a few styles that will fit.
You should have said something the other day at the house, you could have tried the Cobra I have sitting there. It doesn't use stock rails but does mount in the stock position.
Old 10-27-2006, 10:36 AM
wtknght1
wtknght1's Avatar
Yeah, it's worth it. I mounted a Cobra Monaco seat to the stock electric seat rails (with some small fashioned steel angle brackets) when I first started prepping my car. The seat could move any way I wanted using the stock seat controller. Then, I switched over to a set of stock manual seat rails when I needed to drop a few more lbs out of the car. I'm finally down to a set of the Hardbar aluminum seat rails to save even more weight and make the seat mounting stronger.
My best recommendation is to use the Hardbar mounts unless you really need to move the seat up and back quite often. Once I got mine set and in a good spot, I realized I didn't need to move it anymore which is why I got the Hardbar mounts. They are rock solid!!!!!
Old 10-27-2006, 10:45 AM
...Mark...
...Mark...'s Avatar
Hey Chris. I wasn't thinking about it then. I came across a guy locally who is looking for 2 Z06 seats yesterday evening and i figured why not swap them out. The stock vette seats suck in terms of lateral support. The seats in my old 300zx TT were 10 times better and that car was almost 15 years old..
And for the record, i had to have my wife help change that bulb..
Old 10-27-2006, 02:35 PM
...Mark...
...Mark...'s Avatar
Is there a FAQ out there on how to do this mod?
Old 10-27-2006, 03:42 PM
FasterIsBetter
FasterIsBetter's Avatar
I mounted the Caravaggio seats to my stock rails, both driver's and passenger's, and they work fine. I used some of that 3M double sided tape to secure the seat controller to the driver's seat. Driver's seat adjuster and memory work just fine. And I love the seats.
Old 10-27-2006, 04:26 PM
RAFTRACER
RAFTRACER's Avatar
6-way power /memory Sparco Evo in one of my Z's (facilitates multiple drivers). Hardbar mounted Sparco Evo in the other........Hardbar mounting is rigid enough to "rock" vehicle with the seat to settle it, Sparco mounted on factory seat frame in the other car is not.
Old 10-27-2006, 04:32 PM
...Mark...
...Mark...'s Avatar
Originally Posted by RAFTRACER
6-way power /memory Sparco Evo in one of my Z's (facilitates multiple drivers)..
Can i get a little more info on how you did this?
Old 10-27-2006, 04:51 PM
RAFTRACER
RAFTRACER's Avatar
1 Sparco Evo seat, 2 Sparco aluminum side brackets. removed seat from
lower seat frame/transmission assy ( necessary to remove lower seat cover to get to fasteners). Fabricated steel 1" (wide) 1/8" (thick) brace between rear seat attachment points on stock seat frame(probably 20 inches or so long). This created a place to mount Sparco side brackets in the rear , used factory seat mounting locations in front to mount Sparco brackets. Some minor contouring and elongating of holes in factory Sparco brackets were required. No that big of a deal, afternoon, couple of trips to the hardware store, couple of beers.....it will be all good.
Old 10-27-2006, 05:54 PM
HeyFred
HeyFred's Avatar
Here is my seat install.
http://forums.corvetteforum.com/show....php?t=1499761
Seat is adjustable front to back. Have logged several hundred miles driving freeway and city with my seat modification. No issues.
Old 10-28-2006, 03:33 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Default Here's a "how to" Corbeau install ...
http://www.z06vette.com/forums/showt...hlight=corbeau
Old 10-28-2006, 11:49 PM
...Mark...
...Mark...'s Avatar
Thanks, i have seen that. I was interested in how he hooked up his seat to the stock rails and kept the power seat option.
To Aftermarket seats on stock rails?
Quick Reply: Aftermarket seats on stock rails?
