Alignment Specs for C3 Road Racer
I have a 1973 road race car that I need to get aligned. I was curious what camber, caster and toe some of you run on your race cars.
I run slicks (27x14x16 rear) and (27x13x16 front).
I race a C2 (same chassis) and run the following alignment specs: Front 11/2 degrees neg camber, 21/2 degree pos caster, 1/16" toe-out
Rear 11/2 degrees neg camber, 1/16" (total) toe-in
Please note that I ran considerably more negative camber but ate up tires. I recently used a tire pyrometer to adjust camber for even tire temperatures across the tred surface, and ended up with these.
These specs will get you in the ballpark, and allow you to adjust for your personal style, and the track. You can try more aggressive settings if you're only running autocross.
