FS: Michelin s8m slicks
Supporting Vendor
Michelin s8m slicks
Michelin s8m slicks in the following sizes available.
27/65/18, 30/65/18, 30/68/18, 33/68/18, 31/71/18.
1-2 heat cycles. $550.00 a set plus shipping.
Supporting Vendor
Add a zero. 30/650/18 = 300/650/18. Not the same size but you would run 30/65/18 and 33/68/18 or 31/71/18. Much faster than any DOT or Dot R tire.
Michelin mediums are quick and this is a good price. I buy all my Pirelli's from these guys. $700 a tire new for Michelin's most times.
Slicks are interesting when you look at rears for instance. A 31/71/18 is exactly the same overall tire height as a 31/71/19. The 31/71/18 just has a taller/fatter sidewall. Does that makes sense now?
I am betting your fronts are 315/30's. The 335's rears are a little short. You will get more MPH in gear if you go to a 345/35/18 enabling you to carry 3rd a little longer. It does help. Hoosier says 26.8" tall for the 345/35/18 and that's similar to the 33/68/18 Michelin in height.
