FS: Brembo GT brake kit 380/355
This is a complete kit, ready to bolt on.
380mm front rotors, 355mm rear rotors.
The rotor rings were replaced (with genuine Brembo rings) 4 track days ago. There is no appreciable wear, other than normal surface discoloration and micro-cracks.
Included is all hardware, and SS brake lines.
Retail on this kit is over $8300... I'll let it go for $3900.
380 x 32mm front rotors, 355 x 32mm rears, 6 piston front calipers, 4 piston rears.
Front calipers have some scuffing from road debris. Pads are DTC 60/70.
Asking a stupid question here: any chance those rotors can be used as stock Z06 replacements?
Yes, rotors with factory calipers? If you'd consider just selling the rotors alone.
Originally Posted by C6psi
Will 18" wheels still fit over these?
https://www.corvetteforum.com/forums...s-sensors.html
Originally Posted by UrbanKnight
I am local and I bet this might be a nice upgrade...
If you want to out-brake folks at the bus stop, anyway.
