FS: Michelin Pilot Sport cup tires mounted up & ready to run on!!
I am selling my road racing set up. It is Michelin Pilot Sport Cup tires mounted on repro C6 Z06 comp gray split spoke wheels, 18" & 19". I have the center caps too.
The tires are 345 30 19 & 295 30 18. They were road force balanced initially. TPMS are included!!All these need is a new ride to bolt up to! They're ready to go.
The tires have 1 track day on them at NJ Motorsports Park's Lightning circuit (4 sessions of approximately 20 min. each).
They were new tires to me, so I took it pretty easy on them out there.
As you can see in the pics below, the tires have pretty much FULL tread left!
No damage, no patches/plugs. I got them about 1 year ago from Luke at Tirerack. I believe I had them heat cycled at Tirerack!
Date codes are 3610 on the rears and 4711 on the fronts.
The reason I'm selling them is because I got a 2011 Carbon Edition Z06 and sold my 09 Z06. These don't fit over the brakes of the Carbon Z, unfortunately.
The wheels are good track day wheels. 1 has a few minor scratches, the others may have a small scuff or a small chip or 2.
These tires new go for $2096+shipping. The wheels go for about $650.TPMS about $140. That would be $2886+shipping+tax+mounting & balancing. You'd be in for easily over $3,000 to do this set up!!
I will sell them here for $1850+shipping. Local pickup preferred.
PM's or emails are preferred.
Ron
Ron
These should fit just fine on a lowered c6z right? I need tires for my car.
Im at work so i cannot see the pics (webfilter) and am going to re-look at this thread when i get home.
I ran them on a stock height 09 C6Z.
Ron
I use this exact set up on the track and my car is lowered. Drove 4 hrs to Watkins Glen on them (car was loaded down), on big bumps there was a slight 'bump rub' from the rears. On the track there was a very slight rubbing on the rear tire on the outside edge. Fronts only rub when you turn the wheel to full lock. I figure the tires will wear out long before the rubbing on the outside edge becomes an issue.
Let me know. Pm me.
Ron
