Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-01-2005, 09:39 PM   #1
Triple Black 88
CF Senior Member
Triple Black 88's Avatar
Default Replaced Bose...PICS!!!
Just wanted to share some pics and info on my experience replacing the
infamous Bose setup. I bought the Din 1/2 Alpine CDA-D852 off ebay for $187.00. I bought one for my daily driver about a year ago and just fell in love with it. The tri colored display is awesome, and it sounds great...45w x 4. I also bought a GM wire harness and soldered the wires to the Alpine harness outside the car. This made it easy. The stock harness's just plugged right in.
Stereo Install - From the start I didn't want the stereo to stick out of the dash opening like they normally do with the kits. I wanted it to sit behind the bezel like the stock unit and the AC/Heater. To make a long story short, I had to cut the back of the stock bracket off in order to mount the Alpine deep enough for the reveal I wanted. I did buy and use a kit, but I spent a lot of time customizing (rigging) it so it would fit just right. This was time consuming and a PITA.
Rear Speakers - I replaced the original round speakers with Sony 6x9's. I was planning on re-wiring the car, but didn't have to. I removed the factory Box/Speaker/Amp enclosure, cut the wire before the amp, and used the existing wire for the new speaker. The stock speaker was mounted below a plastic plate with a 6x9 opening, so I used that to mount the new 6x9's. The speakers didn't exactly fit flush in the indentation, so I modified it with a Dremmel. I also had to cut the rug which had a round hole to match the 6x9 and also added a tweeter.
Front Speakers - The fronts were tough. I couldn't get the stock enclosures out but while trying I came accross the wires going to the amp. I was so relieved! I cut them, bypassed the amp and wired up the stock speakers. That lasted about a day, they really sounded dull...no highs or lows, all midrange. So I went out and bought a set of Sony 5 1/4's and just made them fit. I had to use 2 layers of weather stripping to seal the airspace from the enclosure because there were gaps between the speaker lip and the molded enclosure.
Let me know what you think
__________________
[IMG][/IMG]
1988 Convertible - Custom Tuned Chip by "ski_dwn_it" (Thanks Jesse), 3.73 Rear, Stainless Dual Exhaust with Borlas(No Cats), B&M Shift Kit, AIR Pump Elim, K&N, Open Lid, Open Shroud w/Custom Ram Air, Modified MAF, Air Foil, Ported Plenum, Underdrive Pullies, Cut Plugs, TB Bypass, MAT Re-locate, No Frisbee, Manual Fan Switch, 160 Stat, Michilin Pilot Sports
NO Engine Work!!!
Best ET was 13.7@100MPH on 5-17-02. Car has 125,000mi.
Triple Black 88 is offline   Reply With Quote
Old 01-01-2005, 09:54 PM   #2
Shore
CF Senior Member
Shore's Avatar
Why is this the first time I have seen this deck??????? I like it.
BUT, My real compliment for you is the cleanness of your interior..It looks new.
Shore is offline   Reply With Quote
Old 01-01-2005, 11:16 PM   #3
snoopdan
CF Senior Member
snoopdan's Avatar
Send a message via AIM to snoopdan
Neat on those mids in the doors man... Much props on them. Like the tweater placement most of all.
and your clean interior makes me sick.
snoopdan
snoopdan is offline   Reply With Quote
Old 01-02-2005, 12:36 AM   #4
bogus
CF Senior Member
Send a message via Yahoo to bogus
looking GREAT!!!
bogus is offline   Reply With Quote
Old 01-02-2005, 12:41 AM   #5
muddpile
CF Senior Member
Looks good, and I love that deck! I wish I would have known that it existed before I bought mine, it fits so perfect. Your system is simple yet effective. Good job.
muddpile is offline   Reply With Quote
Old 01-02-2005, 01:15 AM   #6
screw991le
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Send a message via MSN to screw991le
Had that same head unit in my camaro, nice deck.
__________________
2008 Liquid Red G8 GT P&S
2011 Traverse AWD LTD
screw991le is offline   Reply With Quote
Old 01-02-2005, 01:42 AM   #7
C4DC
CF Senior Member
St. Jude Donor '06
C4DC's Avatar
Looks very nice!
C4DC is offline   Reply With Quote
Old 01-02-2005, 01:46 AM   #8
mikey whipreck
CF Senior Member
mikey whipreck's Avatar
it's hard to find a deck that doesn't clash horribly with the digital dash... good work
mikey whipreck is offline   Reply With Quote
Old 01-02-2005, 11:18 AM   #9
Sportsdude
CF Senior Member
Sportsdude's Avatar
Wow, that has the look of "factory" finish. It's the type of install I'm looking for. Looks great!
Sportsdude is offline   Reply With Quote
Old 01-02-2005, 12:46 PM   #10
Triple Black 88
CF Senior Member
Quote:
Thanks, that's the look I was going for. I've had this car for 10 yrs and have held off on replacing the Stereo because I didn't want to ruin the factory "look". I've seen too many aftermarket units that stick out like a sore thumb.
They stopped making this unit a few years ago, but they do pop up on ebay every once in a while.
Reload this Page Replaced Bose...PICS!!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1995 Polo Green Coupe for sale shottel C4s for Sale/Wanted 17 08-29-2005 09:19 AM
Bose System Gone... JL AUDIO IN!!!! PICS lenny037 C5 General 25 06-15-2005 02:04 PM
Bose out- Kenwood in c6gofst C6 Corvette General Discussion 33 11-03-2004 03:00 AM
FS: '96 CE Coupe LT4 red interior no_radio C4s for Sale/Wanted 17 04-27-2004 10:08 AM
Can you guys post pics of your vettes please? blackLS1 C4 General Discussion 60 08-17-2002 02:07 AM
[pics] Some pics of the things I did to my radio [pics] ('94) XTRME 94 Audio/Electronics 30 04-15-2002 11:22 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
