Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-31-2004, 08:49 PM   #1
TheHammer
CF Senior Member
TheHammer's Avatar
Default Help with Alpine Install
I own a 97 coupe, and have an Alpine model CDA-9827. It has a wire, orange I believe, that should connect to an illumination lead so that the face of the unit will dim when the lights are turned on. There is no wire that connects to the orange wire out of the factory connected harness. Does anyone have a suggestion of how to get this function to work and what wire I need to splice into? Is there an illumination lead close by
i can use?
TheHammer is offline   Reply With Quote
Old 12-31-2004, 09:50 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
Don't fuss with it.
I have never attached a dimmer wire in my life! Then again, not many actually have one!
I suspect to do so, you will need a harness breakdown. I am sure there is one on the radio harness, but the adaptor more than likely does not include it.
bogus is offline   Reply With Quote
Old 12-31-2004, 10:33 PM   #3
snoopdan
CF Senior Member
snoopdan's Avatar
Send a message via AIM to snoopdan
Not worth the effort.
Probaby an orange/white wire on the harness, if its even there. otherwise I x2 what bogus said.
snoopdan
snoopdan is offline   Reply With Quote
Old 01-01-2005, 01:48 PM   #4
TheHammer
CF Senior Member
TheHammer's Avatar
Does anyone know where to get a harness breakdown?
Old 01-01-2005, 07:16 PM   #5
bogus
CF Senior Member
Quote:
It's called the Helms Manual.... www.helminc.com
Or, http://www.corvetteradios.com./Page.html
might help some...
Old 01-01-2005, 07:31 PM   #6
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
I believe the illumination is controlled through the BCM like the ignition wire. I have tagged the illumination wire on the the fog light switch.
EatRice is offline   Reply With Quote
Old 01-01-2005, 08:05 PM   #7
gmosley
CF Senior Member
gmosley's Avatar
Default illumination
from what ive read you can tap illumination from the hvac controls harness
gmosley is offline   Reply With Quote
Old 01-02-2005, 12:02 AM   #8
TheHammer
CF Senior Member
TheHammer's Avatar
Does anyone know which wire that is in the hvac unit is the illumination lead? If not, I will be trying the helms.
Old 01-02-2005, 12:34 AM   #9
bogus
CF Senior Member
did you try the link I posted above?
Old 01-02-2005, 03:13 AM   #10
gmosley
CF Senior Member
gmosley's Avatar
Default test
just a quick question related to the dimmer-illumination wire would the voltage sent to the wire vary with brightness or if not voltage what would vary up or down depending on the switch position
Old 01-02-2005, 11:23 AM   #11
TheHammer
CF Senior Member
TheHammer's Avatar
I tried the link to corvette wires, and the gray wire may be the one. Otherwise, there is no dimmer wire apparently.
Reload this Page Help with Alpine Install
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help with stereo question.......... CountryBoy C4 General Discussion 16 07-19-2003 11:22 AM
BOSE Must Go! Help with choices... monkeyboylawyer Audio/Electronics 17 05-31-2003 04:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
