Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-23-2004, 03:06 PM   #1
Red5
CF Senior Member
Red5's Avatar
Default How do I install a powered sub in a 98 coup?
I have a tube like powered sub and I need to install it inmy 98 coupe. Anyone know what wires I should tie into for power? Or where I need to ge to the speaker connections?
Thanks,
Matt
__________________
This is Red five
Standing by...
KY/OH 2004/5/6/7 SM-II 2008/10 XP Champion.
Cartech Stage II LS-1, Big Tires, Huge smile.
Red5 is offline   Reply With Quote
Old 11-23-2004, 03:23 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
the bose system would require line level adaptors... i don't remember who makes'm, but they will convert the head signal to line level for the sub.
bogus is offline   Reply With Quote
Old 11-23-2004, 04:59 PM   #3
QuikZilver
CF Senior Member
QuikZilver's Avatar
What brand tube? SAS Bazooka? If not, then return it and buy a SAS Bazooka tube. SAS was the original developer of the tube and theirs has the best response compared to any other tube manufacturers.
As for your questions (based on my installations of SAS Bazooka tubes)....
1. I got power, switch power, and ground from the AUX power adaptor.
2. You will need to still tap into your antenna power wire, just find the wire for your power antenna and tap into it.
3. Get the speaker inputs from your rear speakers. If you have an SAS Bazooka, you can tap straight into them and not worry about Line Level adaptors as the amp in the Tube will do it for you.
QuikZilver is offline   Reply With Quote
Old 11-23-2004, 05:14 PM   #4
Red5
CF Senior Member
Red5's Avatar
It actually IS a SA Bazooka.
Will the powert antenna have enough juice to run the amp in the tube?
So I need to tie into teh rear speakers and the antenna wire... That sounds easy enough.
Old 11-24-2004, 09:56 AM   #5
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
NO NO NO, do not use the antenna turn-on as a power source to the red wire of the tube. The ant wire was not designed to handle that much current. It is for a 12 volt turn-on only. There is a great chance you will blow a fuse (hopefully there is a fuse) on that ant lead.
You want to use the ant lead to hook-up to the subs turn-on lead (which is almost always blue) (some tube's amp uses the speaker level input as a turn-on) The red wire will need to go straight to the battery. Black wire to a good ground. Not sure on the music input but I also think you can hook those up straight to the rear speaker wires since I believe the SAS wil take either a low or high level input.
Let us know how it goes
knewblewkorvette is offline   Reply With Quote
Old 11-24-2004, 12:03 PM   #6
Red5
CF Senior Member
Red5's Avatar
Glad I re-read this before doing the install. OK, So I need to run wires to the battery and the remote on to the antenna.
Just so we are on the same page:
Do I want to take the speaker wires from the outside of the speakers and run the to the sub?
Do I take wires from one speaker and or both?
Do I need to run the power directly to the battery?
Also, will this thing fit/mess up my CD changer?
Thanks,
Matt
Old 11-24-2004, 12:26 PM   #7
QuikZilver
CF Senior Member
QuikZilver's Avatar
Thanks,
Matt
Matt,
As for your questions:
1. You can tap into the wires going to your rear speakers, so, yes, from outside the speakers. Easiest way is to use wire taps to crimp onto the wires.
2. For the SAS Bazooka tube, you want to pull from both sides to give a true mono bass sound.
3. You can tap into the AUX power supply at the inside passenger fuse box. Or, use the power tap on the fuse panel under the hood.
4. No, it shouldn't mess up your CD Changer. I am assuming you are going to have the tube above the CD Changer on the storage cover. You may run into a slight skip depending on how good the CD Changer is and how hard the bass is in the music you are playing. I had issues in the past if playing a "bass" CD of a changer and even headunit skipping, but that was when it hit really hard and low. I doubt you will have any problems.
Neil
Old 11-24-2004, 02:04 PM   #8
Red5
CF Senior Member
Red5's Avatar
Matt,
Neil
QuesationL
If I take the pos and neg from the right side and screw them into the pos and neg on the sub..... Then take the pos and neg from the left side and screw them intot he pos and neg on thesub... Won't it create a mono tone for the sub, the right and the left rear speakers?
Reload this Page How do I install a powered sub in a 98 coup?
Tags
install, long, powered
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
