Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-23-2004, 12:39 AM   #1
noelc5
CF Senior Member
Send a message via AIM to noelc5
Default Ideas for an amp rack
Ok guys, I've been thinking of changing up my amp rack. I currently have one that's made of MDF. Nothing too fancy. It sits right behind my head and is angled slightly. It looks decent but I'm thinking it's time for something new. It currently holds 2 amps. I need to be able to mount crossovers for my mids and tweets to the new rack. On a side note, anyone mount their crossovers in the rear speaker compartments ?
+ I want to keep my amps grounded at the same point so basically I'm looking for a new design of the current rack.
+ I want to keep the weight down. I would consider making something out of glass.
Let me know what ideas you guys suggest!
Disclaimer: I hope this makes sense. It's Jaeger time in TN if you know what I mean.
noelc5 is offline   Reply With Quote
Old 11-23-2004, 02:24 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
can you send some pics???
bogus is offline   Reply With Quote
Old 11-25-2004, 04:04 PM   #3
ValleyZ06
CF Senior Member
ValleyZ06's Avatar
I'm going to be building an amp rack to hold two amps behind the driver/passenger like you have. Where did you ground your amps and what gauge wire did you use? Thanks.
ValleyZ06 is offline   Reply With Quote
Old 11-28-2004, 10:26 PM   #4
noelc5
CF Senior Member
Quote:
I used a spot between the two gas tanks for the ground. It works fairly well. I have some noise getting into the lines but nothing very bad. I went and visited a guy on the forum and he drilled the hole. (talk about needing a beer after that)
I ran 2 4 guage wires for power and 2 4 guage wires for ground. My goal was not to every have to rip this car apart for wiring upgrades. Fortunately for me, I already screwed that up and I'm running more speaker wire here in a week or two.
My digital camera absolutely sucks. I have a friend with a new one so when she gets a chance to bring it over here I'll try and snag some pictures.
Old 11-29-2004, 11:38 AM   #5
Shore
CF Senior Member
Shore's Avatar
I ran a 4 gauge for my power from a brass lug termnal on the batt through the door firewall and to a twin 8g dist. block.
I then ran a 4 gauge ground froma brass lug terminal on the batt through another seperate drilled hole in the door firewall and then to a quad 8g dist. block.
I have zero noise at any time and at any volume.I'm pretty certain with these Vettes you need a solid COMMON ground.The battery is just the best one.
Shore is offline   Reply With Quote
Old 11-29-2004, 01:55 PM   #6
mike76002
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08
mike76002's Avatar
I built my amp rack that can hold 2 amps, 4 crossovers, 1 capacitor, and a distributor out of 1/4 MDF so it is not heavy at all since it has many holes to hold all the stuffs
I think my amp rack is weight about 2-3 lbs max.
I got vert so I ground everything to my waterfalls.
Good luck with your project!
-Mike
mike76002 is offline   Reply With Quote
Old 11-29-2004, 02:21 PM   #7
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
Noel, if you have noise, it could be the ground, but I would be more willing guess it is from your HU.
Here are a couple of pics of a covered amp rack I built to hold 2 amps, 2 crossovers, and my 6 disk DVD changer. I made it all out of 1/2" mdf, so its not too heavy. Plexi would look cool also, just need to get yourself a router since the edges will be exposed.
leolufse is offline   Reply With Quote
Old 11-30-2004, 07:27 PM   #8
brianw21
CF Senior Member
brianw21's Avatar
I did 1/4" hard board with an MDF frame, with an carpet covered 1/4" hard board. The result was flush with the ledge and tall enough to cover the amps.
brianw21 is offline   Reply With Quote
Reload this Page Ideas for an amp rack
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Grond Stereo Install finally completed (Pix - dialup beware) EG@EnglandGreen C5 General 114 05-05-2005 10:17 PM
Half way through the weekend project. LS1_redvette Audio/Electronics 13 04-05-2005 09:10 AM
C5 amp racks.. let me see them BayouVette Audio/Electronics 9 02-02-2004 05:36 PM
Anyone build an amp rack? FarmerBob2001 Audio/Electronics 9 04-11-2002 09:07 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
