Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2004, 01:03 AM   #1
noelc5
CF Senior Member
Send a message via AIM to noelc5
Default Stereo Woes...
Ok guys so I'm puzzled right now. I did some work on my baby today, plugs, air filter, brakes, oil, etc. I got everything finished and on the way back from a friend's house my stereo just takes a crap on me.
I'm running a 12 inch woofer powered by an MTX amp, and some ozz audio components powered by an Arc audio amp. Both amps are grounded at the same position. Both amps have the power LED powered up.
I immediately think power. Well the power LED is up. The ground is shared and the bass is actually playing. Wtf?
I thought maybe I considered that maybe I was acting like a chump again and had muted the stereo. Nope. The sub is still playing.
I've turned the cd player off and on a bunch and hit the manual reset button her it. No dice.
Any advice?
noelc5 is offline   Reply With Quote
Old 11-21-2004, 01:36 AM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
what head unit? are you using stock with adaptors?
bogus is offline   Reply With Quote
Old 11-21-2004, 11:17 AM   #3
noelc5
CF Senior Member
I've got a JVC SHKD-99. It's the first JVC that played MP3's. Yah it's old and ghetto lookin' now but it plays and does what I need.
Old 11-21-2004, 12:24 PM   #4
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
Lets split this problem down.
With the stereo off, put the RCA cable that goes to the problem amp into the sub amp. Turn on the stereo. If your sub still works then your problem is the Arc amp. If the sub doesn't work, the problem lies upstream. Do you have an active crossover between the HU and the Arc amp, the fuse could have gone on that as well. Let us know what you find.
PS Some amps have internal fuses. Those can be in the power supply and/or fuses on the speaker outputs.
knewblewkorvette is offline   Reply With Quote
Old 11-21-2004, 03:15 PM   #5
noelc5
CF Senior Member
Hey thanks for the great advice. I dunno why I didn't think of that.
Anyhow... I did exactly as you said and switched the RCAs for each amp. The sub didn't play. ( whew, I had been looking at amps and man I just dont wanna spend any $$ right now). Since the RCA was obviously not sending a signal I hoped maybe it had come loose from the back of the deck. I took apart the dash and noticed it had come loose. The "teeth" on the RCA was bent so I must've bent that while mucking around one day. Anyhow, I squeezed the "teeth" and it held on to the RCA out jack on the back of the deck.
Problem solved.
Thanks!
Old 11-21-2004, 03:40 PM   #6
bogus
CF Senior Member
great!
Old 11-21-2004, 06:39 PM   #7
knewblewkorvette
CF Senior Member
good job
Old 11-22-2004, 12:54 PM   #8
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
Quote:
Originally Posted by knewblewkorvette
good job
glad it was a simple (and inexpensive) fix.
leolufse is offline   Reply With Quote
Reload this Page Stereo Woes...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Emergency modaholics meeting.....please come in WolfeBros C5 General 111 06-27-2005 07:48 AM
big stereo junkies ry C3 Tech/Performance 21 06-09-2003 01:23 PM
Custom car stereo installation woes mozot C4 Tech/Performance 16 11-16-2001 08:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
