Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-19-2004, 12:45 PM   #1
QuikZilver
CF Senior Member
QuikZilver's Avatar
Default Installation of XM Commander in C5 Instructions
I typed this up for a couple of members and thought I would go ahead and post them here.
Installation of XM Commander in C5 Corvette
Note: Directions below are for C5 Corvettes without CD Changer and hooking XM up through AUX input.
Installation below is for 1999 – 2003 Corvettes
Parts needed:
XM Commander (purchased mine from overstock.com: $150)
Factory CD Changer Harness (purchased mine from Litewarehouse.com: $68.99)
PIE Auxiliary Input Connector, GM10-AUX (purchased mine from Litewarehouse.com: $66.99)
Short RCA cable
Double sided tape
3 Electrical Butt Connectors
Tools needed:
Common Screwdriver
Electrical Crimping Tool
How to do it:
1. Prep-Work: Remove passenger side floor mat and passenger side fuse panel cover. Remove passenger side plastic threshold (plastic part that covers the edge of the carpet at the door). Remove passenger side kick panel. Remove ash tray. All of this is just pulled off, no tools necessary.
2. Mount antenna at rear of car. Because the Corvette is fiberglass, it is not necessary to have it mounted on the outside of the vehicle. A couple of good places to mount it: Behind the taillights on the passenger side, Inner fender wheel well behind carpet (I chose this place to mount with double sided tape). After a suitable location is decided on, mount antenna and run antenna wire up on the passenger side, hiding the wiring as you go. Bring it up to the passenger side kick panel.
3. Wiring Harness: Use the auxiliary power source located in the passenger side fuse panel area to get power and ground. Route harness over to passenger side kick panel.
4. Controller: You do not need to remove the center console trim panel to install. Simply fish wire down through rear of ash tray location where you can see light. When you can grab the wire, pull through, leaving a little slack. Using Velcro included with XM Commander, mount controller in the upper area. You should be able to close the outer door. Run controller wire over to passenger side kick panel.
5. CD Changer cable: At the lower right hand corner of the fuse panel area, you should see a plug that looks like one of the two plugs on the CD Changer cable (directions included with the factory harness have a picture of this area). Taped to that wire or taped right near it is another plug that looks like the second plug on the cable. Cut the tape and plug both harnesses into the CD Changer harness. Route CD Changer harness under carpet at passenger side foot well (I used a zigzag pattern so it laid flat under the carpet. Leave enough to bring wire harness up passenger side kick panel.
6. XM Commander Control Box: Plug in the power wire harness, antenna, controller harness and RCA cables into control box. Put double sided tape on back of control box and find a suitable area up on the passenger side kick panel area. You may want to pull the lower dash trim loose to gain more access.
7. AUX Input Connector: Plug RCA cable and CD Changer harness to AUX Input Connector. Place AUX Input Connector up near XM Commander Control Box.
8. Reinstall trim that was removed during installation.
9. Test: Turn on car and turn on XM Commander. Press CD button on deck twice to access CD Changer. You should hear their test broadcast. If you don’t, go back to AUX adaptor and unplug CD Changer harness and plug back in.
10. Call XM Radio to sign up for service.
11. Enjoy cruising with your new XM Commander!
QuikZilver is offline   Reply With Quote
Old 11-23-2004, 04:53 PM   #2
dmeadow
Junior Member
Default For 2004 Coupe using FM Modulator and CD Changer
Thanks, Quikzilver, this was very helpful.
Now here are some comments that should cover the rest of the install types and also provide a couple of alternatives.
In my case, I have a 2004 Coupe (also silver, btw) with a CD Changer. I wanted to keep the CD Changer and the original head unit, so I chose to use the FM Modulator. I’m not as hung up on the sound quality as some are, so the FM Modulator is sufficient for my purposes.
Here are the major differences in the install:
1) You’ll have to remove the console to get at the back of the head unit. Excellent instructions with pictures for doing so can be found at http://www.vetteessentials.com/instr...zel_howto.html. I suggest you use them, since things need to be done in a certain order.
2) The kit includes a relay for the FM Modulator that plugs into the antenna in the back of the head unit, which is why you have to get at the back. The bad news is that the fittings on the relay unit fit all vehicles except later model GM. The good news is that adapter cables are available. I got mine at Circuit City. You’ll need two, one to go from the relay to the head unit, the other for the factory antenna to plug into the relay. The relay can then be stuck to the back of the firewall with double-sided tape. Be careful to put it where it won’t interfere with the re-installation of the head unit.
3) The 2004 Corvette does not have the accessory wire for the power connection. A thread discussing the alternative of using the #22 fuse location can be found here: http://forums.corvetteforum.com/c5-tech/789224-2004-valentine-1-hard-wire-to-power-need-a-little-help.html. I found the connector from Sporty’s catalog at AutoZone, rather than using the spade connector.
Here are some alternative approaches I used that others might find helpful:
1) Upon reading the instructions (which I admit not only goes against my grain, but also my family creed) I found that XM recommends strongly that the antenna be placed on a metal surface of at least 12” by 12”. I suppose the metal acts as part of the antenna. In any case, the instructions say that placement on anything but a metal surface will cause a significant degradation in signal. While apparently this hasn’t hurt Quickzilver’s reception, I decided the better option was to put it on the chassis rail located behind the right rear taillight. I ran the wire up through the drain hole and over the weather seal on the hatch to get it into the cabin. I don’t particularly like the fact that it shows and would be open to suggestions for a better way.
2) I placed the tuner unit under the passenger seat. I couldn’t find a place I liked on the passenger side kick panel as Quickzilver describes it. I ran the control unit wire and the FM relay wire from the console under the tranny tunnel carpet through to the back of the seat. The wires then pop out directly behind the seat and under it to the unit. I stuck the unit in place with double-sided tape, which seems to do a good job of keeping it from moving around. I have a power passenger seat and clearance is not a problem.
dmeadow is offline   Reply With Quote
Old 11-23-2004, 05:02 PM   #3
QuikZilver
CF Senior Member
QuikZilver's Avatar
dmeadow...glad it helped you out some. Thank you as well for adding valuable additional information. Others will really benefit from the information as well!!
Old 11-29-2004, 04:13 PM   #4
NCSU SEE 5
CF Senior Member
St. Jude Donor '05-'06-'07
NCSU SEE 5's Avatar
Location: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
Any Pics?
NCSU SEE 5 is offline   Reply With Quote
Old 12-01-2004, 10:59 PM   #5
gpotski
CF Senior Member
gpotski's Avatar
What is exactly is the "passenger side kick panel" and where is it located??
I would think the Kick panel is near the fuse box on the forward floor area (where the feet go)...
Or is it on the side of the compartment below the doors??
gpotski is offline   Reply With Quote
Old 12-28-2004, 08:16 PM   #6
canesfins
CF Senior Member
canesfins's Avatar
Send a message via AIM to canesfins Send a message via MSN to canesfins Send a message via Yahoo to canesfins
Can someone please give me some guidance in wiring the power for the tuner. I cannot seem to locate the aux power input.
__________________
2004 Corvette Z06
Black with Torch Red Interior
Born on April 29, 2004
Purchased on June 25, 2004
Ecklers Raised Hood, Tigershark Front End, SSR GT7-H 18/19 wheels, AC Delco Ceramic Brake Pads, CAGS Defeat
Stereo: Headunit - Pioneer DEH-P9800BT / iPod / Sirius; Amps - RF P8002 / RF P8004 Speakers - JL XR653-CSi 3-way components; Sub - JL 10W6v2
canesfins is offline   Reply With Quote
Reload this Page Installation of XM Commander in C5 Instructions
Tags
aux, c5, commander, components, corvette, hardwire, input, install, installation, instructions, manual, terk, xm
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
