Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-25-2004, 08:47 PM   #1
Scudd
CF Senior Member
Scudd's Avatar
Default Ground Loop Problem in 97 Yukon
I just had a system installed in my 97 Yukon. After the install, I noticed a slight ground loop/hum. I took it back to the installer, he added a noise suppressor which seemed to work. About a week later the hum came back. It's odd that it happened right after serveral days of rain. After the weather dried out, the hum went away, but now it's back. My question is, has anyone had any luck with changing their spark plug wires to remove noise in a radio? Any other thoughts are welcome.
Scudd is offline   Reply With Quote
Old 09-25-2004, 10:33 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
could you describe the system? are there any external amps? Did the installer have to run wire from the battery to the amps?
A simple head unit swap should not do this.
bogus is offline   Reply With Quote
Old 09-26-2004, 10:19 AM   #3
Scudd
CF Senior Member
Scudd's Avatar
The system has a Alpine head unit and a 4ch. MTX amp, so yes there is a good size power cord coming from the battery. I've check the ground on the amp and its tight, metal on bare metal. Thanks
Old 09-26-2004, 10:38 AM   #4
corvette-pilot
CF Senior Member
corvette-pilot's Avatar
Just a guess but if it is grounded to the body, maybe it is being partially isolated thru the body mounts?? When it rains the water interfers even more??
Maybe try to lengthen the ground wire to a point on the frame to get a true solid ground??
corvette-pilot is offline   Reply With Quote
Old 09-26-2004, 12:55 PM   #5
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
That is your best bet
Chances is that it is a grounding problem. One way to troubleshoot this is to unplug the RCAs going to the amp. (always unplug/plug-in) RCAs with the power off to the stereo). Turn the stereo back on, if the noise is gone ,you have a hum coming done the RCAs. I don't think is the case though and you will still have the hum.
If you do still have the hum, relocate the ground AND to run an extra ground to the chassis from the negitive to the car's chassis. The best way to fix the problem is to run the ground of the amp to the negitive of the battery. Be sure and use the same guage wire as you did for the power wire. You will have ZERO noise like I do
knewblewkorvette is online now   Reply With Quote
Old 09-26-2004, 04:20 PM   #6
splash
CF Member
Another thing to look for, is to make sure that the RCA cables and the power wire are not running along the same side of the truck. They need to be seperated as to not get esd in the RCA cables. So try that and good luck.
splash is offline   Reply With Quote
Old 09-26-2004, 06:16 PM   #7
bogus
CF Senior Member
great suggestions, all!
I run my power down the same side as the battery. You don't want the power crossing the car, because it can pick up noise that way.
Another thing, check the RCAs themselves. If the metal ends are touching, you can pick up a hum.
Finally, check the "gain" setting on the amp. If it's too high, then the amp will pick up and amplify noise. Many Alpine heads have 4V outs, so they will be less prone to picking up this kind of noise.
If nothing else works, you can get a preamp line driver. It will boost the voltage to 16V!!! Serious! This will allow you to drop the gain on the amp to nearly nothing. And all that voltage will act like a force field, keeping the noise away.
Reload this Page Ground Loop Problem in 97 Yukon
Tags
2004, 97, diagram, problems, stereo, wiring, yukon
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 12:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
