Quote:
Originally Posted by Blk98Coupe
I had the same problem with mine. In addition, I noticed that my headlights wouldn't always pop up the first time I turned them on...took several tries before they would come on. Also noticed that my headlights would dim sometimes for a split second. I almost took my car to the dealer when it sounded like even the motor was starting to miss. I checked the battery terminals and found one of them was just barely loose enough to move by hand. I tighten it up and all of the above problems stopped immediately. Worth a try I guess...Good Luck.
You nailed it. Was only loose a couple of quarter turns but fixed the problem. Thanks.
