Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-22-2004, 12:40 AM   #1
No Rice
CF Senior Member
No Rice's Avatar
Default C5 radio mounting
Those of you that replaced your HU, how did you mount the rear of the new deck?
No Rice is offline   Reply With Quote
Old 09-22-2004, 05:35 PM   #2
Vate
CF Senior Member
Vate's Avatar
The back of the factory HU fits into a hole in a tab made of sheet metal. I bent that tab down, toward the back of the car, until it was horizontal, so the the back of my new HU rests on it. I needed to either do that or get rid of it anyway - there's not much room back there.
Vate is offline   Reply With Quote
Old 09-23-2004, 01:21 AM   #3
vrumvrum
CF Senior Member
vrumvrum's Avatar
Some mounts are so solid you don't need a back mount.
vrumvrum is offline   Reply With Quote
Old 09-23-2004, 02:14 AM   #4
LuvmyC5
CF Senior Member
St. Jude Donor '05-'08
LuvmyC5's Avatar
Hey VrumVrum, do you have any mounts finished?
Mine doesn't have a rear support on it and it is pretty strong. Just waiting to buy a VrumVrum mount, as soon Mike gets 'em done.
LuvmyC5 is offline   Reply With Quote
Old 09-23-2004, 02:46 AM   #5
No Rice
CF Senior Member
No Rice's Avatar
Quote:
I sent you an email, looking for one of your mounts. I would like a black with the silver lettering.
Old 10-01-2004, 06:17 PM   #6
Robiwan
CF Senior Member
I put in an Alpine 9825 and used the preamp RCA outputs in the rear. These outputs interfered with the rear wall even with 90 degree elbows. The wall behind the decks is the air channel box for defrosting and upper vents in the dash. I actually used a dremel and carefully cut away a small rectangle so that the RCAs would go in this small hole and the HU would go far enough back. I used some aluminized tape (what you would use to tape up sealed liners like for a wood floor) to cover the opening but pushed it in for clearance for the RCA's, and then everything went fine. I was real disappointed I had to do this, but I used VRumVrum's faceplate and mount, and it looks great. Most people wouldn't even know its not stock.
I only write this so you can be careful on the HU you use, and consider if you are going to use pre amps out, how they physically hook and fit in the car.
Robiwan is offline   Reply With Quote
Reload this Page C5 radio mounting
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
C5 Stereo Install Lessons Learned (long) (all text) MSIP Audio/Electronics 10 06-10-2004 07:29 PM
How are you late model C4 guys mounting aftermarket radios. vrumvrum Audio/Electronics 16 06-09-2003 07:26 PM
C5 Mounting location for XM Satellite Radio Antenna? Hanson Audio/Electronics 15 09-03-2002 01:59 AM
Want to replace C5 Factory unit with MP3 player - advice needed BAD. Venger Audio/Electronics 20 07-17-2002 01:46 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
