Is it possible to make a box that is 1.3 cu ft in the two little storage centers in the back of the car? I'm determined to fit 2 12's in this car but I'm having trouble mounting BOTH subs. I've got the amp figured out. Thanks for the help.
So you would like to make enclosures for the two smaller compartments on the left and right side of the car? Those enclosures need to 1.3 cube? If that is the case no there is not enough airspace...a single 8" just barely fits there. For two 12's you will need to use the larger center compartment and build up a bit higher than that.
Do you need 1.3 for both 12's? What kind of subs are they? 1.3 for 2 12's is a very small enclosure.
I doubt you could even fit the 12" driver in there and close the lid, much less make a box and 12" driver fit in. If you're absolutely determined to make it fit, the reshape the box and reglass it. This way may allow you to keep a flat floor.
Each sub requires 1.3 cu ft of space. They are 12" Audiobahn AQ125T or something like that. 400w RMS.
__________________
2002 Electron Blue Tan topped 6spd vert, Kirban Short Throw, Throttle Body bypass, Borla Twin Tip Stingers, Kooks 1 7/8 long tubes, 3" x-pipe with Random Tech cats, Blackwing Intake, New Air Bridge, Kuhmo Ecstas-RIP
I did some cuft calculations yesterday on the center hole. Looks like if you dont try too hard you can get 1.2 cuft for teh center area if you flush it with the top of the cargo mat. You will need to do some building up and use that area to get the cuft you require.
I have a feeling that this is gonna take a while to build. Oh well. I've got about 6 years before I can put the box in the car so I can build it like I want it. Thanks for the help yall.
__________________
