Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-07-2004, 03:31 PM   #1
pip
CF Senior Member
pip's Avatar
Default How do I move the AC controls?
Please see topic in C5 section:
http://forums.corvetteforum.com/zerothread?id=833576
pip is offline   Reply With Quote
Old 06-07-2004, 07:59 PM   #2
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
Default Re: How do I move the AC controls? (pip)
Depends on how far you want to move them. There is enough slack to put the ac controls in the ash tray location or up where the radio is. The ac is electronic so if you want to move it farther than that you just need to extend the wires.
EatRice is offline   Reply With Quote
Old 06-08-2004, 12:02 AM   #3
jjk2509
CF Senior Member
jjk2509's Avatar
You will need to remove the dash plate and cut the ashtray from the dash plate. You will also need to remove the metal bracket behind the ashtray. A tip is to cut further back into the ashtray and keep removing a little at a time until you remove the right amout. If you cut too much the first time, you will need to do some glass work or get a new dash plate. If you have any questions, send me an e-mail at jeffkelley@cox.net and I will see if I can give you any additional info.
Good luck
jjk2509 is offline   Reply With Quote
Old 06-08-2004, 02:17 PM   #4
pip
CF Senior Member
pip's Avatar
Default Re: How do I move the AC controls? (jjk2509)
Excellent! Just what I needed
Reload this Page How do I move the AC controls?
Tags
ac, c5, control, corvette, remove
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
cell phones, do you??? bdvdvh7 C4 General Discussion 43 12-14-2004 01:06 AM
My baby is finnaly back henchmen3 Audio/Electronics 19 06-17-2004 11:49 AM
Longtime lurker's first (looong) post Islander21 C1 & C2 Corvettes 51 12-20-2002 10:11 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
